I’m running Ubuntu server 25.04 with secure boot enabled which I know is not yet supported. After installing a MOK required by secure boot, I’ve built the 4.23.0 hailo 8 PCIE driver using “make install_dkms” successfully. The driver loads but gets errors trying to load the firmware. I’ve downloaded the 4.23.0 firmware and copied it to
/lib/firmware/hailo
ls -l
-rw-rw-r-- 1 root root 164560 Sep 25 04:07 hailo_fw.bin
On reboot these lines show up in dmesg:
[ 11.051828] hailo_pci: loading out-of-tree module taints kernel.
[ 11.052662] hailo: Init module. driver version 4.23.0
[ 11.052703] hailo 0000:05:00.0: Probing on: 1e60:2864…
[ 11.052709] hailo 0000:05:00.0: Probing: Allocate memory for device extension, 9072
[ 11.052734] hailo 0000:05:00.0: enabling device (0000 → 0002)
[ 11.052796] hailo 0000:05:00.0: Probing: Device enabled
[ 11.052813] hailo 0000:05:00.0: Probing: mapped bar 0 - 000000004b2545b2 16384
[ 11.052824] hailo 0000:05:00.0: Probing: mapped bar 2 - 000000007b5b2258 4096
[ 11.052832] hailo 0000:05:00.0: Probing: mapped bar 4 - 00000000601f1735 16384
[ 11.052846] hailo 0000:05:00.0: Probing: Setting max_desc_page_size to 4096, (page_size=4096)
[ 11.052881] hailo 0000:05:00.0: Probing: Enabled 64 bit dma
[ 11.052887] hailo 0000:05:00.0: Probing: Using userspace allocated vdma buffers
[ 11.052900] hailo 0000:05:00.0: Disabling ASPM L0s
[ 11.052906] hailo 0000:05:00.0: Successfully disabled ASPM L0s
[ 11.053031] hailo 0000:05:00.0: Writing file hailo/hailo8_fw.bin
[ 11.053448] Failed with error -2 to write file hailo/hailo8_fw.bin
[ 11.053455] hailo 0000:05:00.0: Failed writing NNC firmware files. err -2
[ 11.053460] hailo 0000:05:00.0: FW loaded, took 0 ms
[ 11.053464] hailo 0000:05:00.0: Firmware load failed
[ 11.053532] hailo 0000:05:00.0: Failed activating board -2
[ 11.053587] hailo 0000:05:00.0: probe with driver hailo failed with error -2
Can anyone suggest what I should try next to diagnose what I’ve got wrong? The messages indicate the driver is seeing the board but not loading the firmware file. It should be finding its relative path in /lib/firmware as far as I can see.
Thanks in advance for any help.
