Troubleshooting Hailo 4.20: Fixing Import Errors and GStreamer Pipeline Issues After Upgrade
I was working on the following code, which was functioning correctly:
import gi
import gc
import os
import argparse
import setproctitle
import cv2
import time
from datetime import datetime
from collections import defaultdict
import math
import hailo
from hailo_common_funcs import get_numpy_from_buffer, disable_qos
from hailo_rpi_common import get_default_parser, QUEUE, get_caps_from_pad, GStreamerApp, app_callback_class
# Configuración global
CONFIDENCE_THRESHOLD = 0.75
VALID_CLASSES = {'car', 'bus', 'truck', 'person', 'bicycle', 'motorcycle'}
OUTPUT_DIR = "detected_images"
os.makedirs(OUTPUT_DIR, exist_ok=True)
class TrackedObject:
    def __init__(self, label, position, timestamp, confidence):
        self.label = label
        self.position = position  # (x, y)
        self.last_seen = timestamp
        self.confidence = confidence
        self.trajectory = [position]
        self.saved = False
    def update(self, position, timestamp, confidence):
        self.confidence = max(self.confidence, confidence)
        self.trajectory.append(position)
        if len(self.trajectory) > 10:  # Mantener solo los últimos 10 puntos
            self.trajectory.pop(0)
    def get_velocity(self):
        if len(self.trajectory) < 2:
            return (0, 0)
        pos1 = self.trajectory[-2]
        pos2 = self.trajectory[-1]
        return (pos2[0] - pos1[0], pos2[1] - pos1[1])
class UserAppCallbackClass(app_callback_class):
    def __init__(self):
        super().__init__()
        self.tracked_objects = {}
        self.object_count = defaultdict(int)
        self.crossing_line = {
            'start': (400, 600),
            'end': (1000, 600),
            'color': (0, 0, 255),
            'thickness': 3
        self.detection_zone = {
            'top': 500,
            'bottom': 700,
            'min_size': 50,
            'max_size': 400
        self.cooldown_time = 2.0
        self.use_frame = True
        self.position_threshold = 50  # Distancia mínima para considerar objetos diferentes
        self.cleanup_interval = 5.0  # Tiempo en segundos para limpiar objetos antiguos
    def cleanup_old_objects(self, current_time):
        objects_to_remove = []
        for obj_id, tracked_obj in self.tracked_objects.items():
            time_diff = (current_time - tracked_obj.last_seen).total_seconds()
            if time_diff > self.cleanup_interval:
                objects_to_remove.append(obj_id)
        for obj_id in objects_to_remove:
            del self.tracked_objects[obj_id]
    def get_object_id(self, label, position, current_time):
        # Buscar objeto existente cercano
            if tracked_obj.label != label:
                continue
            # Calcular distancia euclidiana
            dx = tracked_obj.position[0] - position[0]
            dy = tracked_obj.position[1] - position[1]
            distance = math.sqrt(dx*dx + dy*dy)
            if distance < self.position_threshold and time_diff < self.cooldown_time:
                return obj_id
        # Si no se encuentra un objeto cercano, crear nuevo ID
        return f"{label}_{position[0]}_{position[1]}_{current_time.strftime('%H%M%S%f')}"
def check_line_crossing(point, line_config, detection_zone):
    if point[1] < detection_zone['top'] or point[1] > detection_zone['bottom']:
        return False
    v1x = line_config['end'][0] - line_config['start'][0]
    v1y = line_config['end'][1] - line_config['start'][1]
    v2x = point[0] - line_config['start'][0]
    v2y = point[1] - line_config['start'][1]
    return (v1x * v2y - v1y * v2x) < 0
    buffer = info.get_buffer()
    if buffer is None:
        return Gst.PadProbeReturn.OK
    if not all([format, width, height]):
    display_frame = frame.copy()
    current_time = datetime.now()
    # Limpiar objetos antiguos periódicamente
    user_data.cleanup_old_objects(current_time)
    try:
        for detection in detections:
            label = detection.get_label()
            if label in VALID_CLASSES and confidence >= CONFIDENCE_THRESHOLD:
                bbox = detection.get_bbox()
                x, y, w, h = [
                    int(v) for v in (
                        bbox.xmin() * width,
                        bbox.ymin() * height,
                        bbox.width() * width,
                        bbox.height() * height,
                if w < user_data.detection_zone['min_size'] or h < user_data.detection_zone['min_size'] or \
                   w > user_data.detection_zone['max_size'] or h > user_data.detection_zone['max_size']:
                    continue
                center_bottom = (int(x + w/2), int(y + h))
                if check_line_crossing(center_bottom, user_data.crossing_line, user_data.detection_zone):
                    obj_id = user_data.get_object_id(label, center_bottom, current_time)
                    if obj_id not in user_data.tracked_objects:
                        user_data.tracked_objects[obj_id] = TrackedObject(label, center_bottom, current_time, confidence)
                        user_data.object_count[label] += 1
                    else:
                        tracked_obj = user_data.tracked_objects[obj_id]
                        tracked_obj.update(center_bottom, current_time, confidence)
                        if not tracked_obj.saved:
                            tracked_obj.saved = True
                            # Guardar imagen
                            if 0 <= x < width and 0 <= y < height:
                                margin = 100
                                x1 = max(0, x - margin)
                                y1 = max(0, y - margin)
                                x2 = min(width, x + w + margin)
                                y2 = min(height, y + h + margin)
                                cropped_image = frame[y1:y2, x1:x2].copy()
                                if cropped_image.shape[0] > 0 and cropped_image.shape[1] > 0:
                                    if cropped_image.shape[0] < 480:
                                        scale_factor = 480 / cropped_image.shape[0]
                                        new_width = int(cropped_image.shape[1] * scale_factor)
                                        cropped_image = cv2.resize(cropped_image, (new_width, 480))
                                    # Añadir información al nombre del archivo
                                    filename = os.path.join(
                                        OUTPUT_DIR,
                                        f"{label}_{confidence:.2f}_{current_time.strftime('%Y%m%d_%H%M%S')}.jpg"
                                    cv2.imwrite(filename, cv2.cvtColor(cropped_image, cv2.COLOR_RGB2BGR))
                    # Dibujar información en el frame
                    cv2.circle(display_frame, center_bottom, 5, (0, 255, 0), -1)
                    cv2.putText(display_frame, f"{label} #{user_data.object_count[label]}",
                              (x, y - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 255, 0), 2)
        # Dibujar línea de cruce y zonas
        cv2.line(display_frame,
                user_data.crossing_line['start'],
                user_data.crossing_line['end'],
                user_data.crossing_line['color'],
                user_data.crossing_line['thickness'])
                (user_data.crossing_line['start'][0], user_data.detection_zone['top']),
                (user_data.crossing_line['end'][0], user_data.detection_zone['top']),
                (0, 255, 0), 1)
                (user_data.crossing_line['start'][0], user_data.detection_zone['bottom']),
                (user_data.crossing_line['end'][0], user_data.detection_zone['bottom']),
                (0, 255, 0), 1)
        user_data.set_frame(display_frame)
    except Exception as e:
        print(f"Error in app_callback: {e}")
class GStreamerYOLOv8App(GStreamerApp):
    def __init__(self, args, user_data):
        super().__init__(args, user_data)
        self.batch_size = 1
        self.network_width = 640
        self.network_height = 640
        self.network_format = "RGB"
        self.source_type = "rpi"
        # Configuración de umbral
        self.nms_score_threshold = 0.3
        self.nms_iou_threshold = 0.45
        self.thresholds_str = f"nms-score-threshold={self.nms_score_threshold} nms-iou-threshold={self.nms_iou_threshold} output-format-type=HAILO_FORMAT_TYPE_FLOAT32"
        # Ruta al modelo YOLOv8
        self.hef_path = os.path.join(
            os.path.dirname(os.path.abspath(__file__)),
            'hailomodel/yolov8s_h8l.hef'
        self.default_postprocess_so = os.path.join(self.postprocess_dir, 'libyolo_hailortpp_post.so')
        self.app_callback = app_callback
        setproctitle.setproctitle("YOLOv8 Detection App")
        self.create_pipeline()
        source_element = ""
        if self.source_type == "rpi":
            source_element = f"libcamerasrc name=src_0 auto-focus-mode=2 ! "
            source_element += f"video/x-raw, format={self.network_format}, width=1536, height=864 ! "
            source_element += QUEUE("queue_src_scale")
            source_element += f"videoscale ! "
            source_element += f"video/x-raw, format={self.network_format}, width={self.network_width}, height={self.network_height}, framerate=30/1 ! "
        elif self.source_type == "usb":
            source_element = f"v4l2src device={self.video_source} name=src_0 ! "
            source_element += f"video/x-raw, width=640, height=480, framerate=30/1 ! "
        elif self.source_type == "file":
            source_element = f"filesrc location={self.video_source} name=src_0 ! "
            source_element += QUEUE("queue_dec264")
            source_element += f" qtdemux ! h264parse ! avdec_h264 max-threads=2 ! "
            source_element += f" video/x-raw,format=I420 ! "
        pipeline_string = "hailomuxer name=hmux "
        pipeline_string += source_element
        pipeline_string += "tee name=t ! "
        pipeline_string += QUEUE("bypass_queue", max_size_buffers=20) + "hmux.sink_0 "
        pipeline_string += "t. ! " + QUEUE("queue_hailonet")
        pipeline_string += "videoconvert n-threads=3 ! "
        pipeline_string += f"hailonet hef-path={self.hef_path} batch-size={self.batch_size} {self.thresholds_str} force-writable=true ! "
        pipeline_string += QUEUE("queue_hailofilter")
        pipeline_string += f"hailofilter so-path={self.default_postprocess_so} qos=false ! "
        pipeline_string += QUEUE("queue_hmuc") + " hmux.sink_1 "
        pipeline_string += "hmux. ! " + QUEUE("queue_hailo_python")
        pipeline_string += QUEUE("queue_user_callback")
        pipeline_string += f"identity name=identity_callback ! "
        pipeline_string += QUEUE("queue_hailooverlay")
        pipeline_string += f"hailooverlay ! "
        pipeline_string += QUEUE("queue_videoconvert")
        pipeline_string += f"videoconvert n-threads=3 qos=false ! "
        pipeline_string += QUEUE("queue_hailo_display")
        pipeline_string += f"fpsdisplaysink video-sink={self.video_sink} name=hailo_display sync={self.sync} text-overlay={self.options_menu.show_fps} signal-fps-measurements=true "
        return pipeline_string
if __name__ == "__main__":
    parser = get_default_parser()
    args = parser.parse_args()
    user_data = UserAppCallbackClass()
    app = GStreamerYOLOv8App(args, user_data)
    app.run()
I was working with Hailo version 4.19, but I accidentally performed an update that installed version 4.20. After upgrading to version 4.20, my code started failing because it could not import some Hailo dependencies used in my script. I reviewed the issue, performed the necessary validations, and updated multiple components, but the issue persisted.
Later, I attempted to downgrade to version 4.19, but the driver remained at 4.20. I gave up on both upgrading and downgrading and decided to standardize everything to version 4.20.
** Current Error**
Now, when I run the following command:
I get the following output:
Identifying board
Control Protocol Version: 2
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8L
Serial Number: HLDDLBB242501236
Part Number: HM21LB1C2LAE
[HailoRT] [error] Ioctl HAILO_READ_NOTIFICATION failed with 22. Read dmesg log for more info
Additional Issue: Running My Code on Hailo 4.20
When I try to execute my code, I receive the following errors:
0:00:00.070670192 3869803 0x5555aaf722d0 WARN      v4l2codecs-h265dec gstv4l2codech265dec.c:1684:gst_v4l2_codec_h265_dec_register: Not registering H265 decoder since it produces no supp  orted format
0:00:00.274744385 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:570:gst_parse_element_make: no element "hailomuxer"
0:00:00.436070430 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:623:gst_parse_element_make: no property "auto-focus-mode" in element "libcamerasrc"
0:00:00.443760462 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:1262:priv_gst_parse_yyparse: link has no source [sink=@0x1c1321c0]
0:00:00.451671382 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:570:gst_parse_element_make: no element "hailofilter"
0:00:00.451734234 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:1262:priv_gst_parse_yyparse: link has no sink [source=@0x1c132ac0]
0:00:00.451828585 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:1262:priv_gst_parse_yyparse: link has no source [sink=@0x1c132dc0]
0:00:00.452157344 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:570:gst_parse_element_make: no element "hailooverlay"
0:00:00.452182029 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:1262:priv_gst_parse_yyparse: link has no sink [source=@0x1c1336c0]
0:00:00.452227992 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:1262:priv_gst_parse_yyparse: link has no source [sink=@0x1c1339c0]
0:00:00.468526849 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:1615:priv_gst_parse_launch: No sink-element named "(null)" - omitting link
0:00:01.094927717 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:1615:priv_gst_parse_launch: No sink-element named "(null)" - omitting link
0:00:01.094966847 3869562     0x1bdfd830 ERROR           GST_PIPELINE gst/parse/grammar.y:1601:priv_gst_parse_launch: No src-element named "hmux" - omitting link
gst_parse_error: no element "hailomuxer" (1)
hailomuxer name=hmux libcamerasrc name=src_0 auto-focus-mode=2 ! video/x-raw, format=RGB, width=1536, height=864 ! queue name=queue_src_scale max-size-buffers=3 max-size-bytes=0 max-siz  e-time=0 ! videoscale ! video/x-raw, format=RGB, width=640, height=640, framerate=30/1 ! tee name=t ! queue name=bypass_queue max-size-buffers=20 max-size-bytes=0 max-size-time=0 ! hmux  .sink_0 t. ! queue name=queue_hailonet max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 ! hailonet hef-path=/home/jhsbeltr/Downloads/proyecto_yolo8/hailomo  del/yolov8s_h8l.hef batch-size=1 nms-score-threshold=0.3 nms-iou-threshold=0.45 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 force-writable=true ! queue name=queue_hailofilter max-size-  buffers=3 max-size-bytes=0 max-size-time=0 ! hailofilter so-path=/usr/lib/hailo-post-processes/libyolo_hailortpp_post.so qos=false ! queue name=queue_hmuc max-size-buffers=3 max-size-by  tes=0 max-size-time=0 !  hmux.sink_1 hmux. ! queue name=queue_hailo_python max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! queue name=queue_user_callback max-size-buffers=3 max-si  ze-bytes=0 max-size-time=0 ! identity name=identity_callback ! queue name=queue_hailooverlay max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailooverlay ! queue name=queue_videoc  onvert max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 qos=false ! queue name=queue_hailo_display max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! fp  sdisplaysink video-sink=xvimagesink name=hailo_display sync=false text-overlay=False signal-fps-measurements=true
** What I Need Help With:**
  1. Resolving the HAILO_READ_NOTIFICATION error shown when running hailortcli fw-control identify.
  2. Understanding how to make my existing code (which worked on version 4.19) run on version 4.20. The main issues seem to be:
  • Missing hailomuxer, hailofilter, and hailooverlay elements in GStreamer.
  • Issues with libcamerasrc properties like auto-focus-mode.
  • Parsing and linking errors in the GStreamer pipeline.
Any guidance on how to fix these errors and adapt my code to Hailo 4.20 would be greatly appreciated.
Hey @jhoanbeltran960810 ,
I see you’re experiencing several issues after upgrading to Hailo 4.20:
  • HAILO_READ_NOTIFICATION error (firmware/driver mismatch)
  • Missing GStreamer elements (hailomuxer, hailofilter, hailooverlay)
  • libcamerasrc auto-focus-mode configuration problems
Here’s how to resolve these issues:
  1. Clean Removal of Previous Installation
sudo apt remove --purge hailo-all
sudo apt autoremove
sudo rm -rf /usr/lib/hailo* /usr/include/hailo* /opt/hailo* /etc/hailo*
  1. Fresh Installation of Hailo 4.20
sudo apt update
sudo apt full-upgrade
sudo apt install hailo-all
This clean installation should resolve the firmware mismatch, restore missing GStreamer plugins, and fix the configuration issues. Let me know if you need any additional help!
I see the driver installation error after the clean installation. The error message indicates that the Hailo driver is not properly installed.
jhsbeltr@raspberrypi:~/Downloads/proyecto_yolo8 $ sudo apt remove --purge hailo-all
sudo apt autoremove
Reading package lists... 0%
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages were automatically installed and are no longer required:
  hailo-tappas-core hailofw hailort ieee-data python3-argcomplete python3-contextlib2 python3-future python3-hailort python3-netaddr
  python3-netifaces rpicam-apps-hailo-postprocess
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
  hailo-all*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 7,168 B disk space will be freed.
(Reading database ... 202172 files and directories currently installed.)
Removing hailo-all (4.20.0) ...
0 upgraded, 0 newly installed, 11 to remove and 0 not upgraded.
After this operation, 297 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 202170 files and directories currently installed.)
Removing rpicam-apps-hailo-postprocess (1.6.0-2) ...
Removing hailo-tappas-core (3.31.0+1-1) ...
Removing hailofw (4.20.0-1) ...
Removing python3-hailort (4.20.0-1) ...
Removing hailort (4.20.0-1) ...
Removing python3-netaddr (0.8.0-2) ...
dpkg: warning: while removing python3-netaddr, directory '/usr/lib/python3/dist-packages/netaddr' not empty so not removed
Removing ieee-data (20220827.1) ...
Removing python3-argcomplete (2.0.0-1) ...
dpkg: warning: while removing python3-argcomplete, directory '/usr/lib/python3/dist-packages/argcomplete/bash_completion.d' not empty so not removed
Removing python3-contextlib2 (0.6.0.post1-3) ...
Removing python3-future (0.18.2-6) ...
dpkg: warning: while removing python3-future, directory '/usr/lib/python3/dist-packages/future/moves' not empty so not removed
Removing python3-netifaces:arm64 (0.11.0-2+b1) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for libc-bin (2.36-9+rpt2+deb12u9) ...
jhsbeltr@raspberrypi:~/Downloads/proyecto_yolo8 $ sudo apt update
Hit:1 https://packages.grafana.com/oss/deb stable InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
Get:5 https://pkgs.tailscale.com/stable/debian bookworm InRelease
Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
Fetched 6,581 B in 1s (9,353 B/s)
All packages are up to date.
W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
The following additional packages will be installed:
Suggested packages:
  python-future-doc ipython3 python-netaddr-docs
The following NEW packages will be installed:
  hailo-all hailo-tappas-core hailofw hailort ieee-data python3-argcomplete python3-contextlib2 python3-future python3-hailort
  python3-netaddr python3-netifaces rpicam-apps-hailo-postprocess
0 upgraded, 12 newly installed, 0 to remove and 0 not upgraded.
Need to get 189 MB of archives.
After this operation, 297 MB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bookworm/main arm64 python3-argcomplete all 2.0.0-1 [34.7 kB]
Get:2 http://deb.debian.org/debian bookworm/main arm64 python3-contextlib2 all 0.6.0.post1-3 [13.5 kB]
Get:3 http://deb.debian.org/debian bookworm/main arm64 python3-future all 0.18.2-6 [348 kB]
Get:4 http://deb.debian.org/debian bookworm/main arm64 ieee-data all 20220827.1 [2,029 kB]
Get:5 http://deb.debian.org/debian bookworm/main arm64 python3-netaddr all 0.8.0-2 [295 kB]
Get:6 http://deb.debian.org/debian bookworm/main arm64 python3-netifaces arm64 0.11.0-2+b1 [16.9 kB]
Get:7 http://archive.raspberrypi.com/debian bookworm/main arm64 hailofw all 4.20.0-1 [448 kB]
Get:8 http://archive.raspberrypi.com/debian bookworm/main arm64 hailort arm64 4.20.0-1 [8,371 kB]
Get:9 http://archive.raspberrypi.com/debian bookworm/main arm64 hailo-tappas-core arm64 3.31.0+1-1 [7,948 kB]
Get:10 http://archive.raspberrypi.com/debian bookworm/main arm64 rpicam-apps-hailo-postprocess arm64 1.6.0-2 [170 MB]
Get:11 http://archive.raspberrypi.com/debian bookworm/main arm64 python3-hailort arm64 4.20.0-1 [335 kB]
Get:12 http://archive.raspberrypi.com/debian bookworm/main arm64 hailo-all all 4.20.0 [1,242 B]
Fetched 189 MB in 39s (4,882 kB/s)
Selecting previously unselected package hailofw.
(Reading database ... 198383 files and directories currently installed.)
Preparing to unpack .../00-hailofw_4.20.0-1_all.deb ...
Unpacking hailofw (4.20.0-1) ...
Selecting previously unselected package hailort.
Preparing to unpack .../01-hailort_4.20.0-1_arm64.deb ...
Unpacking hailort (4.20.0-1) ...
Selecting previously unselected package hailo-tappas-core.
Preparing to unpack .../02-hailo-tappas-core_3.31.0+1-1_arm64.deb ...
Unpacking hailo-tappas-core (3.31.0+1-1) ...
Selecting previously unselected package rpicam-apps-hailo-postprocess.
Preparing to unpack .../03-rpicam-apps-hailo-postprocess_1.6.0-2_arm64.deb ...
Unpacking rpicam-apps-hailo-postprocess (1.6.0-2) ...
Selecting previously unselected package python3-argcomplete.
Preparing to unpack .../04-python3-argcomplete_2.0.0-1_all.deb ...
Unpacking python3-argcomplete (2.0.0-1) ...
Selecting previously unselected package python3-contextlib2.
Preparing to unpack .../05-python3-contextlib2_0.6.0.post1-3_all.deb ...
Unpacking python3-contextlib2 (0.6.0.post1-3) ...
Selecting previously unselected package python3-future.
Preparing to unpack .../06-python3-future_0.18.2-6_all.deb ...
Unpacking python3-future (0.18.2-6) ...
Selecting previously unselected package ieee-data.
Preparing to unpack .../07-ieee-data_20220827.1_all.deb ...
Unpacking ieee-data (20220827.1) ...
Selecting previously unselected package python3-netaddr.
Preparing to unpack .../08-python3-netaddr_0.8.0-2_all.deb ...
Unpacking python3-netaddr (0.8.0-2) ...
Selecting previously unselected package python3-netifaces:arm64.
Preparing to unpack .../09-python3-netifaces_0.11.0-2+b1_arm64.deb ...
Unpacking python3-netifaces:arm64 (0.11.0-2+b1) ...
Selecting previously unselected package python3-hailort.
Preparing to unpack .../10-python3-hailort_4.20.0-1_arm64.deb ...
Unpacking python3-hailort (4.20.0-1) ...
Selecting previously unselected package hailo-all.
Preparing to unpack .../11-hailo-all_4.20.0_all.deb ...
Unpacking hailo-all (4.20.0) ...
Setting up hailofw (4.20.0-1) ...
update-alternatives: using /lib/firmware/hailo/hailo8_fw.4.20.0.bin to provide /lib/firmware/hailo/hailo8_fw.bin (hailo8_fw.bin) in auto mode
Setting up python3-contextlib2 (0.6.0.post1-3) ...
Setting up hailort (4.20.0-1) ...
Setting up python3-netifaces:arm64 (0.11.0-2+b1) ...
Setting up ieee-data (20220827.1) ...
Setting up hailo-tappas-core (3.31.0+1-1) ...
Setting up python3-future (0.18.2-6) ...
update-alternatives: using /usr/bin/python3-futurize to provide /usr/bin/futurize (futurize) in auto mode
update-alternatives: using /usr/bin/python3-pasteurize to provide /usr/bin/pasteurize (pasteurize) in auto mode
Setting up python3-argcomplete (2.0.0-1) ...
Setting up rpicam-apps-hailo-postprocess (1.6.0-2) ...
Setting up python3-netaddr (0.8.0-2) ...
Setting up python3-hailort (4.20.0-1) ...
Setting up hailo-all (4.20.0) ...
jhsbeltr@raspberrypi:~/Downloads/proyecto_yolo8 $  hailortcli fw-control identify
[HailoRT] [error] Can't find hailort driver class. Can happen if the driver is not installed, if the kernel was updated or on some driver failure (then read driver dmesg log)
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_NOT_INSTALLED(64) - Failed listing hailo devices
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_NOT_INSTALLED(64)
Can you help me resolve this?
A reboot is required after installation.
Please lets us know if your issue is solved.
Hi @giladn, I have performed the restart after installation and I am still experiencing the same error.
jhsbeltr@raspberrypi:~ $ hailortcli fw-control identify
Best regards.
Hello guys, can you please help me with this issue?
Hi @jhoanbeltran960810
Please run the commands line by line to make sure all commands are ran.
If possible start from a fresh OS to make sure no stale installations are causing issues.
If this does not work please send some more information by running these commands:
sudo lsmod | grep hailo
sudo dmesg | grep -i hailo
sudo apt list | grep hailo
