After installing and testing the packages we built for the Hailo-10H M.2 AI Accelerator Module on a Raspberry Pi 5 using Slackware AARch64 Linux, it’s all looking rather promising and working perfectly - so far!
TEST ENVIRONMENT
Host : Raspberry Pi 5 (maia)
OS : Slackware AArch64 -current
Kernel : 6.18.26-v8-sairpi5_64
HailoRT : 5.3.0
Build : 06May26
Packages installed:
kernel-rpi5-6.18.26-armv8-1_slackcurrent_06May26_sai.txz
kernel-modules-rpi5-6.18.26-armv8-1_slackcurrent_06May26_sai.txz
kernel-headers-rpi5-6.18.26-armv8-1_slackcurrent_06May26_sai.txz
rpi5-boot-firmware-armv8-1_slackcurrent_06May26_sai.txz
hailort-rpi5-5.3.0-armv8-1_slackcurrent_06May26_sai.txz
hailort-pcie-drv-rpi5-5.3.0-armv8-1_slackcurrent_06May26_sai.txz
hailort-nnc-drv-rpi5-5.3.0-armv8-1_slackcurrent_06May26_sai.txz
hailo-10h-firmware-5.3.0-armv8-1_slackcurrent_06May26_sai.txz
TEST 001 - PCIe DEVICE DETECTION
Command : lspci
Result : PASS
Hailo-10H detected at 0001:06:00.0:
0001:06:00.0 Co-processor: Hailo Technologies Ltd. Hailo-10H AI Processor (rev 01)
TEST 002 - KERNEL DRIVER AND FIRMWARE LOAD
Command : dmesg | grep -i hailo
Result : PASS
Driver hailo1x_pci loaded, firmware programmed successfully:
hailo1x 0001:06:00.0: Firmware loaded in 1589 ms
hailo1x 0001:06:00.0: Device created at /dev/h1x-0
Firmware files loaded:
hailo/hailo10h/customer_certificate.bin
hailo/hailo10h/scu_fw.bin
hailo/hailo10h/u-boot-0.dtb.signed
hailo/hailo10h/u-boot-spl.bin
hailo/hailo10h/fitImage
hailo/hailo10h/image-fs
TEST 003 - HAILORTCLI DEVICE SCAN
Command : hailortcli scan
Result : PASS
Hailo Devices:
[-] Device: pci/0001:06:00.0
TEST 004 - FIRMWARE VERSION IDENTIFICATION
Command : hailortcli fw-control identify
Result : PASS
Executing on device: pci/0001:06:00.0
Identifying board
Control Protocol Version: 2
Firmware Version: 5.3.0 (release,app)
Logger Version: 0
Device Architecture: HAILO10H
TEST 005 - DEVICE MONITOR
Command : hailortcli monitor
Result : PASS
Device ID Architecture NNC Utilization (%) CPU Utilization (%) RAM Utilization (%) RAM Usage (MB) On Die Temperature (C) On Die Voltage (mV)
pci/0001:06:00.0 HAILO10H 0.0 0.0 1.3 90 / 7221 37.9 800
TEST 006 - DEVICE RUNTIME LOGS
Command : hailortcli logs runtime
Result : PASS
Mar 9 12:48:58 hailo10 authpriv.err getty[558]: /dev/ttyS1: not a tty
Mar 9 12:49:08 hailo10 authpriv.err getty[561]: /dev/ttyS1: not a tty
Mar 9 12:49:18 hailo10 authpriv.err getty[564]: /dev/ttyS1: not a tty
Mar 9 12:49:18 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Changed device state to D0
Mar 9 12:49:18 hailo10 user.info HailoRT-Server: [device.cpp:54] [Device] OS Version: Linux 5.15.32-yocto-standard-01685-g4cd9cfd0e6e7 #1 SMP PREEMPT Wed Feb 18 10:02:32 UTC 2026 aarch64
Mar 9 12:49:18 hailo10 user.info HailoRT-Server: [control.cpp:89] [control__parse_identify_results] firmware_version is: 5.3.0
Notes:
The Hailo-10H runs its own internal Linux system (hostname: hailo10, kernel:
5.15.32 Yocto, aarch64). The runtime log is from that internal system, not
the Raspberry Pi host. The getty /dev/ttyS1 errors are from the device’s own
inittab and can be ignored — they are not related to the host or this build.
TEST 007 - DEVICE SYSTEM CONTROL LOGS
Command : hailortcli logs system_control
Result : PASS
[ 0.000000] SCU-FW v1.10.0 [04da82d5] (based on SCP-Firmware v2.14.0 [cef63ea3], Hailo SCMI v0.50.1)
[ 0.000000] [CC] LCS: 5
[ 0.000000] [MERCURY_FUSES_INFO] Chip Serial Number: E8EBFDDBDEDFF769D7CE73F9
[ 0.000000] [MERCURY_FUSES_INFO] H265 fuse out is set
[ 0.000000] [MERCURY_FUSES_INFO] ISP fuse out is set
[ 0.006303] [FWK] Module initialization complete!
[ 0.028059] [MBIST] ISP subserver is not supported, skipping vision mbist
[ 0.028281] [MBIST] H265 subserver is not supported, skipping H265 mbist
[ 0.048821] [BOOT] SCU-FW notified PCIe host, ready to receive boot DTB image
[ 0.059799] [BOOT] PCIe host completed sending boot DTB image
[ 0.070842] [CFG] Calculating DDR config node hash…
[ 0.074612] [CFG] DDR config node CRC32 hash: 0x1643089324 (total: 8588 bytes)
[ 0.075700] [CFG] Calculating DDR patch node hash…
[ 0.076388] [CFG] DDR patch node CRC32 hash: 0x1503807951 (total: 888 bytes)
[ 0.132651] [DDR] DDR #0 initialized successfully (8 GiB, 4266MT/s, BIST)
[ 0.162379] [BOOT] SCU-FW notified PCIe host that DRAM is initialized, ready to receive DRAM image
[ 0.731332] [BOOT] PCIe host completed sending DRAM image
[ 0.769502] [SYSTEM] Starting AP…
[ 0.769641] [SYSTEM] AP initialized successfully
[ 0.822187] [BOOT] AP bootloader (U-Boot) has successfully booted
[ 1.229108] [POWER] Failed to power off pcie: clocks are still on
[ 1.230946] [PD] Transition of pcie from to failed: E_DEVICE
[ 2.209133] [BOOT] AP software (Linux) has successfully booted
Notes:
SCU-FW v1.10.0 confirmed. DDR 8 GiB initialised successfully. AP (Linux)
booted successfully. The PCIe power state transition failure is expected
behaviour — PCIe clocks remain active while the host is communicating with
the device.
TEST 008 - DEVICE NNC LOGS
Command : hailortcli logs nnc
Result : PASS (with note)
Output is binary data, not human-readable text.
Notes:
The nnc log type returns raw binary output. This is expected — the NNC
(Neural Network Core) log data is not intended for direct terminal display.
TEST 009 - POWER CONSUMPTION
Command : hailortcli measure-power
Result : PASS
Current power consumption (W): 0.673171
TEST 010 - KERNEL MODULES, DEVICE NODE AND FIRMWARE FILES
Command : lsmod | grep hailo
Result : PASS
hailo1x_pci 147456 0
Command : ls -la /dev/h1x-0
Result : PASS
crw------- 1 root root 510, 0 May 6 13:37 /dev/h1x-0
Command : ls /lib/firmware/hailo/hailo10h/
Result : PASS (with finding - see FINDING 002)
customer_certificate.bin scu_fw.bin u-boot-11.dtb.signed u-boot-3.dtb.signed u-boot-9.dtb.signed
fitImage u-boot-0.dtb.signed u-boot-12.dtb.signed u-boot-4.dtb.signed u-boot-default.dtb.signed
hailo10h_fw.tar.gz u-boot-1.dtb.signed u-boot-13.dtb.signed u-boot-5.dtb.signed u-boot-spl.bin
image-fs u-boot-10.dtb.signed u-boot-14.dtb.signed u-boot-6.dtb.signed
FINDING 002 - hailo10h_fw.tar.gz PRESENT IN FIRMWARE DIRECTORY
Observed in : TEST 010 - Firmware Files
Status : Reported to Hailo
The file hailo10h_fw.tar.gz is present in /lib/firmware/hailo/hailo10h/
alongside the extracted firmware files. Investigation shows this tarball is
contained within itself — the outer hailo10h_fw.tar.gz extracts to include
a copy of hailo10h_fw.tar.gz as one of its contents.
The firmware loads correctly and the device operates normally. The nested
tarball is redundant and should not be installed to /lib/firmware/. This is
a Hailo packaging issue.
FINDING 001 - HAILO-10H INTERNAL GETTY ERROR ON /dev/ttyS1
Observed in : TEST 006 - Device Runtime Logs
The Hailo-10H runtime log contains repeating errors:
The Hailo-10H runs an internal Yocto-based Linux system. Its inittab has an
entry spawning getty on /dev/ttyS1 — a serial console intended for hardware
debug use. When the device is deployed via PCIe with no physical serial
connection, the TTY does not exist. Getty fails, init attempts to respawn it,
fails again, and eventually disables it.
This is a Hailo firmware/Yocto image configuration issue. The errors are
harmless in a PCIe-only deployment but should be addressed in the firmware.
TEST SUMMARY
All available hailortcli tests completed successfully.
Tests run:
001 lspci - PCIe device detection
002 dmesg | grep -i hailo - Kernel driver and firmware load
003 hailortcli scan - Device scan
004 hailortcli fw-control identify - Firmware identification
005 hailortcli monitor - Device monitor
006 hailortcli logs runtime - Device runtime logs
007 hailortcli logs system_control - Device system control logs
008 hailortcli logs nnc - Device NNC logs
009 hailortcli measure-power - Power consumption
Tests not run:
hailortcli run, run2, benchmark, parse-hef - require a compiled HEF network
file which is outside the scope of this test.
