Tensor_meta.hpp missing error
Hey @Karthikeyan_S,
Is this still an issue? This appears to be a build-related problem. What architecture are you using and how did you build it? The error suggests the system can’t locate tensors.hpp, which should be available in a proper build setup.
If you have more info about this issue , please add it so i can move it to the R&D team of tappas , thanks
