Tensor_meta.hpp missing error
i am getting the same error. when i checked for the hpp file, i was only able to find out common/tensors.hpp
(hailo_tappas_venv) smartan@smartan:~/Downloads/tappas_v3.31.0/core/hailo/build$ ninja
[1/130] Compiling C++ object plugins/l…p/gray_scale_gsthailonv12togray.cpp.o
FAILED: plugins/libgsthailotools.so.3.31.0.p/gray_scale_gsthailonv12togray.cpp.o
c++ -Iplugins/libgsthailotools.so.3.31.0.p -Iplugins -I…/plugins -I…/general -I…/plugins/common -Imetadata -I…/metadata -Itracking -I…/tracking -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/orc-0.4 -I/usr/include/opencv4 -I/usr/include/pgm-5.3 -I/usr/include/libxml2 -fvisibility=default -fdiagnostics-color=always -D_FILE_OFFSET_BITS=64 -Wall -Winvalid-pch -Wnon-virtual-dtor -std=c++17 -O3 -Wpessimizing-move -Wredundant-move -fconcepts -fPIC -pthread -isystem /usr/include/mit-krb5 -isystem…/…/…/open_source/rapidjson -isystem…/…/open_source/rapidjson -isystem…/…/…/open_source/xtensor_stack/base -isystem…/…/open_source/xtensor_stack/base -DHAVE_CONFIG_H -MD -MQ plugins/libgsthailotools.so.3.31.0.p/gray_scale_gsthailonv12togray.cpp.o -MF plugins/libgsthailotools.so.3.31.0.p/gray_scale_gsthailonv12togray.cpp.o.d -o plugins/libgsthailotools.so.3.31.0.p/gray_scale_gsthailonv12togray.cpp.o -c …/plugins/gray_scale/gsthailonv12togray.cpp
…/plugins/gray_scale/gsthailonv12togray.cpp:6:10: fatal error: common/tensors.hpp: No such file or directory
6 | #include “common/tensors.hpp”
compilation terminated.
[2/130] Compiling C++ object plugins/l…o.3.31.0.p/filter_gsthailofilter.cpp.o
FAILED: plugins/libgsthailotools.so.3.31.0.p/filter_gsthailofilter.cpp.o
c++ -Iplugins/libgsthailotools.so.3.31.0.p -Iplugins -I…/plugins -I…/general -I…/plugins/common -Imetadata -I…/metadata -Itracking -I…/tracking -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/orc-0.4 -I/usr/include/opencv4 -I/usr/include/pgm-5.3 -I/usr/include/libxml2 -fvisibility=default -fdiagnostics-color=always -D_FILE_OFFSET_BITS=64 -Wall -Winvalid-pch -Wnon-virtual-dtor -std=c++17 -O3 -Wpessimizing-move -Wredundant-move -fconcepts -fPIC -pthread -isystem /usr/include/mit-krb5 -isystem…/…/…/open_source/rapidjson -isystem…/…/open_source/rapidjson -isystem…/…/…/open_source/xtensor_stack/base -isystem…/…/open_source/xtensor_stack/base -DHAVE_CONFIG_H -MD -MQ plugins/libgsthailotools.so.3.31.0.p/filter_gsthailofilter.cpp.o -MF plugins/libgsthailotools.so.3.31.0.p/filter_gsthailofilter.cpp.o.d -o plugins/libgsthailotools.so.3.31.0.p/filter_gsthailofilter.cpp.o -c …/plugins/filter/gsthailofilter.cpp
…/plugins/filter/gsthailofilter.cpp:6:10: fatal error: common/tensors.hpp: No such file or directory
[10/130] Compiling C++ object tracking…racker.so.3.31.0.p/hailo_tracker.cpp.o
ninja: build stopped: subcommand failed.
even after updating the meson build and converting the headers to use tensors.hpp i get another error
ninja
[8/130] Compiling C++ object plugins/l…p/gray_scale_gsthailograytonv12.cpp.o
FAILED: plugins/libgsthailotools.so.3.31.0.p/gray_scale_gsthailograytonv12.cpp.o
c++ -Iplugins/libgsthailotools.so.3.31.0.p -Iplugins -I…/plugins -I…/general -I…/plugins/common -I…/libs/postprocesses/common -Imetadata -I…/metadata -Itracking -I…/tracking -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/orc-0.4 -I/usr/include/opencv4 -I/usr/include/pgm-5.3 -I/usr/include/libxml2 -fvisibility=default -fdiagnostics-color=always -D_FILE_OFFSET_BITS=64 -Wall -Winvalid-pch -Wnon-virtual-dtor -std=c++17 -O3 -Wpessimizing-move -Wredundant-move -fconcepts -fPIC -pthread -isystem /usr/include/mit-krb5 -isystem…/…/…/open_source/rapidjson -isystem…/…/open_source/rapidjson -isystem…/…/…/open_source/xtensor_stack/base -isystem…/…/open_source/xtensor_stack/base -DHAVE_CONFIG_H -MD -MQ plugins/libgsthailotools.so.3.31.0.p/gray_scale_gsthailograytonv12.cpp.o -MF plugins/libgsthailotools.so.3.31.0.p/gray_scale_gsthailograytonv12.cpp.o.d -o plugins/libgsthailotools.so.3.31.0.p/gray_scale_gsthailograytonv12.cpp.o -c …/plugins/gray_scale/gsthailograytonv12.cpp
…/plugins/gray_scale/gsthailograytonv12.cpp: In function ‘GstFlowReturn gst_hailograytonv12_prepare_output_buffer(GstBaseTransform*, GstBuffer*, GstBuffer**)’:
…/plugins/gray_scale/gsthailograytonv12.cpp:59:72: error: ‘TENSOR_META_API_NAME’ was not declared in this scope
59 | if (!gst_buffer_get_meta(parent_meta->buffer, g_type_from_name(TENSOR_META_API_NAME)))
[9/130] Compiling C++ object plugins/l…o.3.31.0.p/filter_gsthailofilter.cpp.o
c++ -Iplugins/libgsthailotools.so.3.31.0.p -Iplugins -I…/plugins -I…/general -I…/plugins/common -I…/libs/postprocesses/common -Imetadata -I…/metadata -Itracking -I…/tracking -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/orc-0.4 -I/usr/include/opencv4 -I/usr/include/pgm-5.3 -I/usr/include/libxml2 -fvisibility=default -fdiagnostics-color=always -D_FILE_OFFSET_BITS=64 -Wall -Winvalid-pch -Wnon-virtual-dtor -std=c++17 -O3 -Wpessimizing-move -Wredundant-move -fconcepts -fPIC -pthread -isystem /usr/include/mit-krb5 -isystem…/…/…/open_source/rapidjson -isystem…/…/open_source/rapidjson -isystem…/…/…/open_source/xtensor_stack/base -isystem…/…/open_source/xtensor_stack/base -DHAVE_CONFIG_H -MD -MQ plugins/libgsthailotools.so.3.31.0.p/filter_gsthailofilter.cpp.o -MF plugins/libgsthailotools.so.3.31.0.p/filter_gsthailofilter.cpp.o.d -o plugins/libgsthailotools.so.3.31.0.p/filter_gsthailofilter.cpp.o -c …/plugins/filter/gsthailofilter.cpp
…/plugins/filter/gsthailofilter.cpp: In function ‘void get_tensors_from_meta(GstBuffer*, HailoROIPtr)’:
…/plugins/filter/gsthailofilter.cpp:313:66: error: ‘TENSOR_META_API_NAME’ was not declared in this scope
313 | if (!gst_buffer_get_meta(pmeta->buffer, g_type_from_name(TENSOR_META_API_NAME)))
…/plugins/filter/gsthailofilter.cpp:318:68: error: ‘GstHailoTensorMeta’ does not name a type; did you mean ‘HailoTensorPtr’?
318 | const hailo_vstream_info_t vstream_info = reinterpret_cast<GstHailoTensorMeta >(gst_buffer_get_meta(pmeta->buffer, g_type_from_name(TENSOR_META_API_NAME)))->info;
| HailoTensorPtr
…/plugins/filter/gsthailofilter.cpp:318:87: error: expected ‘>’ before ‘
’ token
…/plugins/filter/gsthailofilter.cpp:318:87: error: expected ‘(’ before ‘
’ token
318 | const hailo_vstream_info_t vstream_info = reinterpret_cast<GstHailoTensorMeta *>(gst_buffer_get_meta(pmeta->buffer, g_type_from_name(TENSOR_META_API_NAME)))->info;
…/plugins/filter/gsthailofilter.cpp:318:88: error: expected primary-expression before ‘>’ token
…/plugins/filter/gsthailofilter.cpp:318:142: error: ‘TENSOR_META_API_NAME’ was not declared in this scope
…/plugins/filter/gsthailofilter.cpp:318:171: error: expected ‘)’ before ‘;’ token
Hey @Karthikeyan_S,
Is this still an issue? This appears to be a build-related problem. What architecture are you using and how did you build it? The error suggests the system can’t locate tensors.hpp, which should be available in a proper build setup.
If you have more info about this issue , please add it so i can move it to the R&D team of tappas , thanks
