TAPPAS pipeline on raspberry pi 5
Hey everybody, i found some code which helped me to run a network on the Raspberry Pi with the AI Kit.
I found it here How do I increase the max queue size for HailoRT? - #4 by omria.
import numpy as np
from hailo_platform import (
    HEF, VDevice, HailoStreamInterface, InferVStreams,
    ConfigureParams, InputVStreamParams, OutputVStreamParams, FormatType
def run_inference(hef_path, num_images=1):
    # Load model
    hef = HEF(hef_path)
    # Setup device and configure model
    with VDevice() as device:
        # Configure network
        config_params = ConfigureParams.create_from_hef(
            hef=hef,
            interface=HailoStreamInterface.PCIe
        configuration = device.configure(hef, config_params)
        network_group = configuration[0]
        # Setup streams
        input_params = InputVStreamParams.make(
            network_group,
            format_type=FormatType.FLOAT32
        output_params = OutputVStreamParams.make(
            network_group,
        # Prepare input data
        input_info = hef.get_input_vstream_infos()[0]
        h, w, c = input_info.shape
        dataset = np.random.rand(num_images, h, w, c).astype(np.float32)
        # Run inference
        with network_group.activate():
            with InferVStreams(network_group, input_params, output_params) as pipeline:
                results = pipeline.infer({input_info.name: dataset})
                return results
This was a good starting point for me.
