I used the RPI5, and I made a model using pytorch framework.
This model is slow but can be used for inference on RPI CPUs.
So I want to use Hailo-8L because it is slow, but I want to know if the operators I use are available on that NPU.
For example, is stft or GeLU activation function possible in Hailo-8L?
Does it matter if it’s PyTorch, TensorFlow or TFLite? Or can you check if it works?
And if it doesn’t work, is there a way to make it work?
Thank you for your question! Below is the information regarding the supported operators and frameworks for Hailo devices, specifically the Hailo-8L. This will address whether your model using STFT or GeLU activations will be compatible with the Hailo-8L NPU and provide potential workarounds if they are not natively supported.
1. Supported Operators on Hailo NPUs
Hailo devices, including the Hailo-8L, support a broad range of operations. As per the documentation:
Other operators: Expand, ReduceL2, Square, InstanceNormalization
Unfortunately, STFT (Short-Time Fourier Transform) is not listed among the natively supported operations. However, Hailo’s flexible compiler might allow for customization or preprocessing to transform operations that aren’t directly supported into compatible formats.
2. Framework Compatibility
Hailo devices are compatible with multiple frameworks, including:
TensorFlow / TensorFlow Lite
PyTorch
Keras and ONNX models
The framework you use (PyTorch, TensorFlow, or TFLite) won’t significantly affect compatibility, as long as the operations used are available after the model is converted and compiled using the Hailo Dataflow Compiler.
3. Workaround for Unsupported Operators
If certain operators like STFT are not natively supported, consider these options:
Preprocess STFT off-chip: Perform the STFT on the CPU or a separate processing unit, and feed the transformed data into the Hailo NPU for further inference.
Approximate Operators Using Supported Layers: GeLU, for example, can be approximated using other supported non-linear activations such as SiLU or Hard-Swish if required.
Custom Models and Tuning: With Hailo’s Dataflow Compiler, there is room to optimize or adapt unsupported layers into compatible operations during compilation. You may experiment with ONNX conversion or replacing unsupported blocks using TensorFlow Lite’s operators.
4. Summary and Recommendation
GeLU is supported, though still in preview, meaning it is available but may undergo further optimization.
STFT is not currently supported natively on Hailo-8L. It is recommended to preprocess it outside the NPU.
Your use of PyTorch is fully supported, along with other frameworks such as TensorFlow and TFLite.
There are still parts that I don’t fully understand.
Is there a way to directly check for unsupported operators in a PyTorch (.th) model that I’ve created? For example, not just activation functions or STFT, but various PyTorch functions like view_as_complex or hann_window. Do I need to manually compare these with the functions listed in the Hailo Dataflow Compiler User Guide?
So, even though Hailo’s flexible compiler says it might allow transformations for unsupported operations, does that mean the user has to manually replace them with supported operators? It doesn’t automatically change unsupported operations into similar ones for compilation, right?
Lastly, if I were to preprocess the STFT outside the NPU, would the following approach be correct?
Currently, I’m using an RPI5, and my plan is to first perform the STFT transformation outside the NPU. Then, I’ll create a new model that takes the STFT-transformed data as input, run that model on the NPU, and finally, apply the inverse STFT (ISTFT) as post-processing. Is this the correct approach? Thank you.
Is there a way to request the addition of currently unsupported operators (while using the same hardware)? If they are added to the compiler, does that mean the NPU device’s firmware would also need to be updated?
Since it’s my first time using an NPU, there are many things I don’t know, which is why I have so many questions.
