Stuck when trying to create a container in docker
Hello all!
I’m running this and I’m currently stuck on the step to unzip the file and create a docker container, as my pc just gets stuck in the “Loading docker image”
Terminal is as follows
simon@simon-ThinkPad-T14s-Gen-3:~/Documents/Internship/code$ cd hailo8_ai_sw_suite_2025-10_docker/
simon@simon-ThinkPad-T14s-Gen-3:~/Documents/Internship/code/hailo8_ai_sw_suite_2025-10_docker$ ls
hailo8_ai_sw_suite_2025-10.tar.gz
simon@simon-ThinkPad-T14s-Gen-3:~/Documents/Internship/code/hailo8_ai_sw_suite_2025-10_docker$ ./hailo_ai_sw_suite_docker_run.sh
Loading Docker image: /home/simon/Documents/Internship/code/hailo8_ai_sw_suite_2025-10_docker/hailo8_ai_sw_suite_2025-10.tar.gz
INFO: Checking system requirements…
WARNING: It is recommended to have 32 GB of RAM, while this system has only 27 GB.
INFO: No GPU connected.
INFO: System requirements check finished successfully.
The only problem i see happening would be the 16gb of ram, I am now using a bit of swap aswell, but it still doesn’t justify waiting for 2h in this and nothing happening
I haven’t found a similar problem, thank you for your time!
I just downloaded and installed the new Hailo-8 AI Software Suite Docker on Ubuntu 22.04. Everything worked as expected.
Unpacking and starting a new container should take between 5-10 minutes on an SSD. During the installation the RAM usage was very low. The Docker image requires quite a bit of hard drive space.
If this is a first time installation of Docker. It may be useful to restart the system after adding your user to the docker group (see guide step 1).
REPOSITORY                   TAG       IMAGE ID       CREATED        SIZE
hailo8_ai_sw_suite_2025-10   1         3a94fa154926   7 days ago     17.5GB
