goal is to download the correct software for Hailo 15.
At the link 2025-07 (for Hailo-10/15) | Hailo
I get info that “You do not have permission to access this page.“
On the other hand I can download under https://hailo.ai/developer-zone/software-downloads/
the file “Hailo AI Software Suite – Self Extractable / hailo8_ai_sw_suite_2025-07.run“
but that is tagged as Hailo-8/8L.
So not sure if both should download identical software?
Thanks
David
Access to software and documentation for Hailo-15 is restricted and needs to be approved (see PM).
The Hailo AI Software Suite was divided into two versions. One for Hailo-8/8L and one for Hailo-15 and Hailo-10. The version for Hailo-8/8L is available for all community users. The version for Hailo-10/Hailo-15 will be available with the next release (expected in October).
The software is identical from a usage and workflow point of view. However there are architectural differences between Hailo-8/8L and Hailo-10/Hailo-15 and separating the tool into two variants makes validation easier.
