Simple question about hailo integration tool
we use Hailo 4.23 version both rockchip cpu device ( ubuntu os ) and intel cpu device ( windows os )
I tried running tests through the hailo integration tool like in the previous version. However, it doesn’t seem like there is a hailo integration tool compatible with that version, so does that mean integration tool testing is impossible with this 4.23 version?
Hi @Yu_Eunsang :waving_hand:
The empty column is not a mistake in the table. The tool was renamed to Hailo
Accelerator Integration Tool
and it follows its own release cycle, so it does not
ship with the suite anymore — you have to search “integration” in the Developer Zone
downloads. The last version I have seen mentioned is v1.20, tied to HailoRT 4.20.
And that tie is a hard one, it is not just a documentation thing. The tool links
against the exact libhailort version. On 4.23 the library is installed like this,
with no backward symlink:
$ ls -l /usr/lib/libhailort.so*
lrwxrwxrwx  /usr/lib/libhailort.so -> /usr/lib/libhailort.so.4.23.0
-rw-r--r--  /usr/lib/libhailort.so.4.23.0
So a prebuilt tool made for 4.20 will fail with libhailort.so.4.20.0: cannot open shared object file. The same thing happened here with 1.19 running on 4.20. You can
rebuild the tool from source pointing the CMakeLists at 4.23, but I did not test that.
That said, if what you need is the tests and not the tool itself, hailortcli ships
with 4.23 and covers most of them. This is on a Hailo-8L M.2, HailoRT 4.23.0, Ubuntu:
$ hailortcli run yolo26s_hailo8l.hef -t 10 --measure-temp
  Network group: yolo26s
    Frames count: 564
    FPS: 56.21
    Send Rate: 552.52 Mbit/s
    Recv Rate: 635.97 Mbit/s
  Device: 0000:06:00.0
    Minimum chip temperature: 40.9077C
    Average chip temperature: 42.5356C
    Maximum chip temperature: 43.3865C
Send/Recv Rate is the PCIe traffic of the real inference, so it also works as a
bandwidth check. For a stress test you only raise -t (-t 172800 for 48h). And
hailortcli benchmark <hef> gives you FPS and latency in one run:
FPS     (hw_only)                 = 56.0163
        (streaming)               = 57.41
Latency (hw)                      = 16.1918 ms
One warning, power did not work on my board:
[HailoRT CLI] [error] CHECK failed - Power measurement not supported.
Disable the power-measure option
--measure-power needs a board exposing the DVMs and --measure-current needs M.2
with overcurrent protection — mine has neither, so if you need power numbers that
is the part you cannot replace with hailortcli. I only ran this on Linux, I don’t
know if the Windows build behaves the same.
Hope this helps!
We have released Hailo Accelerator Integration Tool v1.24.0 for HailoRT 4.24.0 . However, we identified an issue affecting some models and are preparing a fix, which we expect to release in the coming days.
HailoRT CLI is supported on both Linux and Windows. We also provide the Hailo Accelerator Integration Tool for Windows.
As @Jesus_Royeth mentioned, you can use HailoRT CLI to perform similar tests. You can use the precompiled models from the Hailo Model Zoo to run realistic performance tests without writing an application.
For a single model, use run
hailortcli run model.hef
For a more complex pipeline with multiple models, use run2
hailortcli run2 set-net model1.hef --frame-rate 20 set-net model2.hef
If you have a Hailo-8 M.2 module from Hailo that includes the INA power monitor, you can also measure power consumption.
