Hi everyone,
I’m attempting to run DinoV2/V3 models on Hailo hardware, but I’ve run into some challenges that I’d like to clarify with the community.
Context:
From what I understand, the Hailo Dataflow Compiler (DFC) doesn’t fully support certain internal layers used in Dino models. As a workaround, I found the ONNX Runtime Hailo Execution Provider and hoped to run the exported Dino ONNX model directly, leveraging at least partial acceleration from the Hailo device.
Current Status:
I successfully compiled the model and can run inference using ONNX Runtime.
However, when monitoring with
hailortcli monitor, the Hailo device does not appear to be utilized. -
It seems the inference falls back to CPU execution, even though the ONNX Runtime Hailo examples use the accelerator correctly.
Questions:
What is the correct workflow to convert an ONNX model with the DFC when some layers are unsupported? Is there documentation or a working example for generating a Hailo-compatible ONNX file?
Are there plans to further develop or expand ONNX Runtime Hailo integration, especially for models with unsupported layers?
Is it feasible to run Dino models on Hailo in any form (e.g., partial offloading), or would you recommend an alternative approach?
The ONNX Runtime README mentions potential “extraction capabilities” in the DFC — is this feature planned or available to help support models like Dino?
Any guidance or pointers would be greatly appreciated.
Thank you in advance for your help!
Best,
Francesco
