Running Hailo 8L on NXP i.MX 6Q
Hey we are trying to get Hailo 8L accelerator on NXP i.MX6 platform. I suppose there is no official support for 32 Bit platform but I still tried. I used the the scarthgap release of meta-hailo and did encounter compiler error.
Claude was able to fix the errores with minor patches, and the build succeeded. I wanted to ask weather these patch is fine or will cause issues.
Following for pcie driver
Date: Sun, 13 Jul 2026 00:00:00 +0000
Subject: [PATCH] fix 32-bit ARM build errors in hailo-pci driver
On 32-bit ARM (iMX6 Cortex-A9), dma_addr_t is u32 (no LPAE) so the
declaration in vdma_common.h conflicts with the u64 in the implementation.
Also size_t is unsigned int on 32-bit so %lx format is wrong; use %zx.
--- a/common/vdma_common.h	2026-07-13 11:24:11.286006686 +0530
+++ b/common/vdma_common.h	2026-07-13 11:24:11.289006649 +0530
@@ -182,7 +182,7 @@
         channel, channel_index)
 void hailo_vdma_program_descriptors_in_chunk(
-    dma_addr_t chunk_addr,
+    u64 chunk_addr,
     unsigned int chunk_size,
     struct hailo_vdma_descriptors_list *desc_list,
     u32 starting_desc,
--- a/linux/vdma/ioctl.c	2026-07-13 11:24:11.287006673 +0530
+++ b/linux/vdma/ioctl.c	2026-07-13 11:24:11.291006624 +0530
@@ -250,7 +250,7 @@
         return -EINVAL;
-    hailo_dev_dbg(controller->dev, "mapping buffer <0x%lx + 0x%lx> tgid: %u\n",
+    hailo_dev_dbg(controller->dev, "mapping buffer <0x%lx + 0x%zx> tgid: %u\n",
                   params.addr_or_fd, params.size, current->tgid);
     buffer = find_buffer(context, params, direction);
@@ -304,11 +304,11 @@
         return -EINVAL;
-    hailo_dev_dbg(controller->dev, "unmap user buffer <0x%lx + 0x%lx>\n", params.addr_or_fd, params.size);
+    hailo_dev_dbg(controller->dev, "unmap user buffer <0x%lx + 0x%zx>\n", params.addr_or_fd, params.size);
     if (NULL == buffer) {
-        hailo_dev_warn(controller->dev, "buffer <0x%lx + 0x%lx> not found\n", params.addr_or_fd, params.size);
+        hailo_dev_warn(controller->dev, "buffer <0x%lx + 0x%zx> not found\n", params.addr_or_fd, params.size);
         return -EINVAL;
Userspace libraries
Subject: [PATCH] fix 32-bit ARM: cast return to size_t in get_async_queue_size
Expected<T>(T&&) requires an rvalue. On 64-bit, returning uint32_t into
Expected<size_t> (where size_t=u64) produces an implicit widening conversion
creating a temporary rvalue. On 32-bit ARM size_t==uint32_t so no conversion
occurs, leaving a const lvalue that cannot bind to T&&. Add explicit cast.
--- a/hailort/libhailort/src/net_flow/pipeline/configured_infer_model_hrpc_client.cpp	2026-07-13 11:47:25.667625591 +0530
+++ b/hailort/libhailort/src/net_flow/pipeline/configured_infer_model_hrpc_client.cpp	2026-07-13 11:47:25.668625579 +0530
@@ -442,7 +442,7 @@
 Expected<size_t> ConfiguredInferModelHrpcClient::get_async_queue_size() const
-    return m_max_ongoing_transfers;
+    return static_cast<size_t>(m_max_ongoing_transfers);
 hailo_status ConfiguredInferModelHrpcClient::validate_bindings(const ConfiguredInferModel::Bindings &bindings)
Is this fine or any other recommended way to use it with 32bit platform
