Hello everyone,
I’m working on a project where I’d like to attach a Hailo-8 AI accelerator to the BeagleBone AI-64 through its M.2 E-key connector. Hardware-wise, I understand I may need an adapter and will be limited to a single PCIe lane, but my main concern right now is the software support.
Does the HailoRT / Hailo Dataflow Compiler officially support running on the BeagleBone AI-64 (Debian arm64)?
Has anyone here successfully installed the Hailo drivers and runtime on this board?
Are there prebuilt packages or instructions available for BeagleBone (similar to what exists for Raspberry Pi or x86 Ubuntu)?
Any tips on kernel version compatibility or pitfalls I should expect during installation?
My goal is to compile models with Hailo’s toolchain and deploy them directly on the BeagleBone AI-64. Before I dive into setting everything up, I’d like to confirm whether this software stack has been tested or if there are workarounds (e.g., cross-compiling, building from source, or using containerized environments).
Thanks in advance to anyone who can share their experience or point me toward the right documentation!
