Run hailo-CLIP on a remote rpi fails
I have the following configuration:
hailo-CLIP runs fine on my rpi5. It takes the image from a connected rpi3 camera and sends the output and detection results to the desktop and in parallel to a rtsp server. I edited therefore the detection_pipeline and “tee’d” the stream over to my Homeassistant rtsp server in parallel.
Everything works as desired.
Now I want to deploy the rpi and the camera to a remote location to survey the cats in my backyard. The rpi then is no longer connected to a monitor nor mouse/keyboard.
When I now ssh into the rpi, and then start the clip application, I get the following gstreamer error:
$ ./catcam_CLIP_start.sh
Setting up the environment...
Setting up the environment for hailo-tappas-core...
TAPPAS_VERSION is 3.30.0. Proceeding...
You are not in the hailo_clip_venv virtual environment.
Virtual environment exists. Activating...
TAPPAS_POST_PROC_DIR set to /usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes
DEVICE_ARCHITECTURE is set to: HAILO8
2025-01-22 16:09:48,350 - clip_app.logger_setup - INFO - PIPELINE:
gst-launch-1.0 appsrc name=app_source is-live=true leaky-type=downstream max-buffers=3 ! videoflip name=videoflip video-direction=horiz ! video/x-raw, format=RGB, width=1280, height=720 !  queue name=source_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! videoscale name=source_videoscale n-threads=2 ! queue name=source_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! videoconvert n-threads=3 name=source_convert qos=false ! video/x-raw, pixel-aspect-ratio=1/1, format=RGB, width=1280, height=720  !         tee name=clip_t hailomuxer name=clip_hmux         clip_t. ! queue name=clip_bypass_q leaky=no max-size-buffers=20 max-size-bytes=0 max-size-time=0  ! clip_hmux.sink_0         clip_t. ! queue name=clip_muxer_queue leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! videoscale n-threads=4 qos=false ! queue name=clip_inference_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! videoscale name=clip_inference_videoscale n-threads=2 qos=false ! queue name=clip_inference_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! video/x-raw, pixel-aspect-ratio=1/1 ! videoconvert name=clip_inference_videoconvert n-threads=2 ! queue name=clip_inference_hailonet_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! hailonet name=clip_inference_hailonet hef-path=/home/StephanS/hailo-CLIP/resources/clip_resnet_50x4.hef batch-size=8  vdevice-group-id=1  scheduler-timeout-ms=1000  scheduler-priority=16  force-writable=true  ! queue name=clip_inference_hailofilter_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! hailofilter name=clip_inference_hailofilter so-path=/home/StephanS/hailo-CLIP/resources/libclip_post.so   qos=false ! queue name=clip_inference_output_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0   ! clip_hmux.sink_1         clip_hmux. ! queue name=clip_hmux_queue leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0   !          hailopython name=pyproc module=/home/StephanS/hailo-CLIP/clip_app/clip_hailopython.py qos=false  !         queue name=clip_postprocess_queue leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  !         identity name=identity_callback  ! 	    queue name=hailo_display_overlay_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! hailooverlay name=hailo_display_overlay  ! textoverlay text="Detection Pipeline" valignment=top halignment=right font-desc="Areal, 12" ! tee name=myrtspstream ! queue name=hailo_display_videoconvert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! videoconvert name=hailo_display_videoconvert n-threads=2 qos=false ! queue name=hailo_display_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0  ! fpsdisplaysink name=hailo_display video-sink=autovideosink sync=false text-overlay=True signal-fps-measurements=true myrtspstream. ! videoconvert ! video/x-raw, format=I420 ! x264enc tune=zerolatency bitrate=500 speed-preset=superfast ! video/x-h264, profile=baseline ! rtspclientsink location=rtsp://localhost:8554/mystream
appsrc properties:  <__gi__.GstAppSrc object at 0x7fffb0590040 (GstAppSrc at 0xd6e4460)>
[0:05:51.510238826] [4339]  INFO Camera camera_manager.cpp:325 libcamera v0.3.2+99-1230f78d
[0:05:51.517894656] [4340]  INFO RPI pisp.cpp:695 libpisp version v1.0.7 28196ed6edcf 29-08-2024 (16:33:32)
[0:05:51.528761246] [4340]  INFO RPI pisp.cpp:1154 Registered camera /base/axi/pcie@120000/rp1/i2c@88000/imx708@1a to CFE device /dev/media3 and ISP device /dev/media1 using PiSP variant BCM2712_C0
[0:05:51.532516077] [4339]  INFO Camera camera.cpp:1197 configuring streams: (0) 1280x720-RGB888 (1) 1280x720-RGB888 (2) 1536x864-BGGR_PISP_COMP1
[0:05:51.532645929] [4340]  INFO RPI pisp.cpp:1450 Sensor: /base/axi/pcie@120000/rp1/i2c@88000/imx708@1a - Selected sensor format: 1536x864-SBGGR10_1X10 - Selected CFE format: 1536x864-PC1B
Picamera2 configuration: width=1280, height=720, format=RGB
picamera_process started
2025-01-22 16:09:48,873 - clip_app.logger_setup - INFO - No text embedding runtime selected, adding new text is disabled. Loading /home/StephanS/hailo-CLIP/embeddings.json
2025-01-22 16:09:48,873 - clip_app.logger_setup - INFO - Loading embeddings from /home/StephanS/hailo-CLIP/embeddings.json
2025-01-22 16:09:48,875 - clip_app.logger_setup - INFO - Text box 0 is set to negative: True
2025-01-22 16:09:48,875 - clip_app.logger_setup - INFO - Text box 5 is set to negative: True
2025-01-22 16:09:48,876 - clip_app.logger_setup - INFO - Setting detection threshold to: 0.76
2025-01-22 16:09:51,692 - clip_app.logger_setup - INFO - State change failed.
2025-01-22 16:09:51,730 - clip_app.logger_setup - ERROR - Error: gst-resource-error-quark: GStreamer encountered a general resource error. (1) ../sys/kms/gstkmssink.c(2032): gst_kms_sink_show_frame (): /GstPipeline:pipeline0/GstFPSDisplaySink:hailo_display/GstAutoVideoSink:autovideosink0/GstKMSSink:autovideosink0-actual-sink-kms:
drmModeSetPlane failed: Permission denied (13)
Is there any solution to run CLIP from remote, not directly from the desktop?
hi @schiwo1
The CLIP application defaults to using a display. When you connect via SSH, the application attempts to render output to the terminal, but there’s no X server available. To fix this, you can configure the Raspberry Pi to use its local display by setting the $DISPLAY environment variable:
export DISPLAY=:0
Make sure you run this in the same terminal where you start the CLIP application.
You can try disabling the CLIP application’s UI and display, though that might be more involved.
Alternatively, enabling VNC on the Pi will let you interact as if you were directly on the Pi itself.
