I noticed that in the official example video the demo runs at about 150 FPS, but when I run the same example on the same hardware, I only get around 30 FPS on average.
What could be causing this difference, and how can I improve the performance on my setup?
Other issue you can run into, is driver/firmware mismatch when the app using the TPU is dockerized.
It is the case with frigate NVR, RPiOS hailo driver is behind, you have to uninstall the packages and manually install hailo8 driver (& firmware) with the script from frigate’s doc.
also wanted to call out the fact that if you are using a pcie splitter such as the Raft from SunFounder that you will slow down your Hailo8L by splitting the bandwidth to it with the other device (such as an nvme HDD)
