Well, as soon as I posted, I took a break and upon returning, I didn’t want to downgrade my hailort driver, so I decided to kick off a custom Frigate container build.
I earlier had download from Github the Frigate repo. So I just did a git swtich dev to get the branch where the HailoRT 4.23.0 branch is located. As part of my earlier research I had read, in
frigate/docker/main/install_hailort.sh that it download hailort drivers. itt was a simple change to modifiy hailot_version to hailo_version=“4.23.0”.
A quick Grok prompt to determine custom Frigate build steps:
- cd frigate
- make local (default target)
That was it, so I started the build.
The build took ~ 2449.8s / 41m on my Rpi 5 8mb, with Hailo8 attached. I had no expectation on how long it would take
make local
echo ‘VERSION = “0.17.0-b5d2f86a”’ > frigate/version.py
echo ‘VITE_GIT_COMMIT_HASH=b5d2f86a’ > web/.env
docker buildx build --target=frigate --file docker/main/Dockerfile .
–tag frigate:latest
–load
[+] Building 2449.8s (78/78) FINISHED docker:default
Caveat Emptor: I have not tested, all I have done is build Frigate with HailoRT 4.23.0.
Overall I am happy it just built with no errors.
I verified image:
docker images | grep frigate
WARNING: This output is designed for human readability. For machine-readable output, please use --format.
frigate:latest 6b6eb00e77bc 5.92GB 1.33GB
ghcr.io/blakeblackshear/frigate:stable cf4305d9f1c6 3.37GB 866MB U
I modified Frigate compose image to run Frigate:latest.
services:
frigate:
image: frigate:latest
I brought the custom docker container up:
docker compose -f /opt/frigate/standalone_compose.yml -p frigate up -d
NAME STATUS CONFIG FILES
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
[+] up 2/2
NAME STATUS CONFIG FILES 0.8s
frigate running(1) /opt/frigate/standalone_compose.yml
c0e0bee38e1a frigate:latest “/init” 6 seconds ago Up 5 seconds (health: starting) 127.0.0.1:5000->5000/tcp, 0.0.0.0:8554-8555->8554-8555/tcp, [::]:8554-8555->8554-8555/tcp, 0.0.0.0:8555->8555/udp, [::]:8555->8555/udp frigate
Here is log file on startup, still some errors /config issues to work through but no driver mismatch errors:
docker container logs frigate
s6-rc: info: service s6rc-fdholder: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-fdholder successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service prepare: starting
s6-rc: info: service log-prepare: starting
s6-rc: info: service log-prepare successfully started
s6-rc: info: service nginx-log: starting
s6-rc: info: service go2rtc-log: starting
s6-rc: info: service frigate-log: starting
s6-rc: info: service certsync-log: starting
s6-rc: info: service go2rtc-log successfully started
s6-rc: info: service prepare successfully started
s6-rc: info: service go2rtc: starting
s6-rc: info: service nginx-log successfully started
s6-rc: info: service frigate-log successfully started
s6-rc: info: service certsync-log successfully started
s6-rc: info: service go2rtc successfully started
s6-rc: info: service go2rtc-healthcheck: starting
s6-rc: info: service frigate: starting
s6-rc: info: service go2rtc-healthcheck successfully started
s6-rc: info: service frigate successfully started
s6-rc: info: service nginx: starting
2026-01-01 17:10:06.438439860 [INFO] Starting NGINX…
2026-01-01 17:10:06.502308100 [INFO] No TLS certificate found. Generating a self signed certificate…
2026-01-01 17:10:06.834847338 [INFO] Preparing Frigate…
2026-01-01 17:10:07.173326237 [INFO] Preparing new go2rtc config…
2026-01-01 17:10:07.479155176 [INFO] Starting Frigate…
2026-01-01 17:10:07.903339596 [INFO] Starting go2rtc…
2026-01-01 17:10:08.448054581 17:10:08.447 INF go2rtc platform=linux/arm64 revision=df95ce3 version=1.9.10
2026-01-01 17:10:08.448097026 17:10:08.448 INF config path=/config/go2rtc_homekit.yml
2026-01-01 17:10:08.448825652 17:10:08.448 INF [api] listen addr=:1984
2026-01-01 17:10:08.450743570 17:10:08.449 INF [rtsp] listen addr=:8554
2026-01-01 17:10:08.450749811 17:10:08.449 INF [webrtc] listen addr=:8555
2026-01-01 17:10:08.451306346 17:10:08.451 ERR github.com/AlexxIT/go2rtc/internal/homekit/homekit.go:128 > error=“no interfaces for listen”
s6-rc: info: service nginx successfully started
s6-rc: info: service certsync: starting
2026-01-01 17:10:12.921007102 [INFO] Starting certsync…
s6-rc: info: service certsync successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
2026-01-01 17:10:15.314158539 [2026-01-01 17:10:15] frigate.util.config INFO : Checking if frigate config needs migration…
2026-01-01 17:10:15.333891440 [2026-01-01 17:10:15] frigate.util.config INFO : frigate config does not need migration…
2026-01-01 17:10:15.364925740 [2026-01-01 17:10:15] frigate.app INFO : Starting Frigate (0.17.0-b5d2f86a)
2026-01-01 17:10:15.386560152 [2026-01-01 17:10:15] peewee_migrate.logs INFO : Starting migrations
2026-01-01 17:10:15.387397537 [2026-01-01 17:10:15] peewee_migrate.logs INFO : There is nothing to migrate
2026-01-01 17:10:15.420268959 [2026-01-01 17:10:15] frigate.app INFO : Recording process started: 452
2026-01-01 17:10:15.449080823 [2026-01-01 17:10:15] frigate.app INFO : Review process started: 465
2026-01-01 17:10:15.452425791 [2026-01-01 17:10:15] frigate.app INFO : go2rtc process pid: 124
2026-01-01 17:10:15.846956832 [2026-01-01 17:10:15] frigate.app INFO : Embedding process started: 475
2026-01-01 17:10:15.924725386 [2026-01-01 17:10:15] frigate.app INFO : Output process started: 532
2026-01-01 17:10:16.009745891 [2026-01-01 17:10:16] frigate.camera.maintainer INFO : Camera processor started for frontcam: 573
2026-01-01 17:10:16.136506319 [2026-01-01 17:10:16] frigate.camera.maintainer INFO : Capture process started for frontcam: 631
2026-01-01 17:10:16.229906772 [2026-01-01 17:10:16] frigate.api.fastapi_app INFO : Starting FastAPI app
2026-01-01 17:10:16.264170725 [HailoRT] [warning] HEF was compiled for Hailo8L device, while the device itself is Hailo8. This will result in lower performance.
2026-01-01 17:10:16.264563446 [HailoRT] [warning] HEF was compiled for Hailo8L device, while the device itself is Hailo8. This will result in lower performance.
2026-01-01 17:10:16.335357028 2026/01/01 17:10:16 [error] 226#226: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: “GET /api/version HTTP/1.1”, subrequest: “/auth”, upstream: “http://127.0.0.1:5001/auth”, host: “localhost:5000”
2026-01-01 17:10:16.335541120 2026/01/01 17:10:16 [error] 226#226: *1 auth request unexpected status: 502 while sending to client, client: 127.0.0.1, server: , request: “GET /api/version HTTP/1.1”, host: “localhost:5000”
2026-01-01 17:10:16.426038732 [INFO] Starting go2rtc healthcheck service…
2026-01-01 17:10:16.533351129 [2026-01-01 17:10:16] frigate.api.fastapi_app INFO : FastAPI started
Have fun
