Raspberry pi 5 AI kit with kinect
Is there any way on how can I integrate the kinect on raspberry pi with hailo to run an instance segmentation with depth data?
If you’re looking to integrate the Kinect with a Raspberry Pi, I recommend checking out the Raspberry Pi forums - they’re more likely to have relevant discussions and resources for that setup. Be sure to use the search function, as you’ll probably find existing threads that can point you in the right direction.
Once you’ve successfully captured frames from the Kinect, you can use your Hailo device to run instance segmentation on them. If you need help with that part, feel free to ask here!
