Following up on the 4B discussion above: we now reproduced a recalculation failure outside Hailo, using the official nominal checkpoint with original BF16 weights. No new Hailo requests were made. This helps narrow our earlier report; we are not attributing these content errors solely to the HEF/compiler.
Also, we have tightened our earlier assessment of the Hailo English recalculation response: mentioning 12 did not resolve its causal contradiction. Those were content errors, not merely wording reservations.
Reference: Qwen/Qwen3-4B-Instruct-2507, revision cdbee75f17c01a7cc42f958dc650907174af0554, official shard SHA-256 values verified. Apple M1 Pro / 16 GB, Python 3.12.16 arm64, MLX 0.32.4 / MLX-LM 0.32.2; 398 loaded BF16 parameter tensors, no weight cast or added weight/KV quantization.
We froze four exact previous baseline messages: two programs × EN/FR, three seeds each (17/29/43). Fresh context/cache, one user message, no supplied system/tools/oracle; sampling T=0.7, top_p=0.8, top_k=20, min_p=0, penalties off, max 512. MLX applies top_p before top_k and temperature at categorical sampling; we do not claim sampler or seed equivalence with Hailo.
| Program |
Reference content observations |
Completion |
Original assignment example: x=2; y=x+3; x=9; print(y) |
No material mechanism defect observed in 6/6 |
STOP 6/6 |
Variant with a second y=x+3 after x=9 |
Material mechanism/coverage errors in 6/6 |
STOP 6/6 |
There were no truncations or generation technical failures. Three French responses also contained 影响. These are small exposed-case engineering observations, not reliability estimates or a measured source-versus-HEF error-rate comparison.
One exact representative request (English variant, seed 17):
Explain why changing x does or does not change y.
```python
x = 2
y = x + 3
x = 9
y = x + 3
print(y)
At most two sentences. No headings or additional examples.
Unchanged raw streamed response, reported STOP/EOS 151645:
Changing x does not change y because y is assigned the value of x + 3 at the time of assignment, and after the first assignment, y is stored as 5. When x is later changed to 9, the value of y remains 5 since it was already computed and stored.
The program prints 12 because the second assignment to y reevaluates x+3. This response instead says y remains 5. The raw/model IDs, exact four inputs and all twelve responses are retained in the data-only packet.
Could you provide a build manifest or equivalent provenance record for this exact artifact?
Qwen3-4B-Instruct-2507.hef, 5,656,354,387 bytes, SHA-256:
033e4e3b2c90d41b2f02620144f4faa0908e7333e98b8766c6c63b9cdbb93d6e
Specifically: source repository + immutable revision + original shard hashes; any weight/fine-tuning deltas; compiler/exporter build and relevant weight/embedding transformation recipe; and confirmation of the intended tokenizer/template assets.
The pinned catalogue supports the nominal text2507 identity, but the public manifest leaves parent_model empty and does not identify a source revision. Our earlier VL-template observation does not identify the weights. Static vocabulary/ordered-merge comparison matches nominal definitions; a seven-row embedding check rejected only simple affine rounding, with exporter transformations still unknown. Neither finding establishes a different checkpoint or a compiler defect.
We therefore keep this checkpoint as a nominal reference, not a verified source of the HEF. The provenance record would let us define a matched comparison before arranging further tests.
Exact four messages, all twelve original reference responses, configuration and shard hashes
"model": {
"repo": "Qwen/Qwen3-4B-Instruct-2507",
"revision": "cdbee75f17c01a7cc42f958dc650907174af0554",
"official_url": "https://huggingface.co/Qwen/Qwen3-4B-Instruct-2507/tree/cdbee75f17c01a7cc42f958dc650907174af0554",
"source_identity": "Nominal reference only. Exact source of the HEF has not been confirmed by the producer.",
"shard_manifest": [
"file": "model-00001-of-00003.safetensors",
"bytes": 3957900840,
"sha256": "75311d91bb08cf0b882913da464a1e722a31fb44db35208663487efb7a3d8ed6",
"official_LFS_sha256": "75311d91bb08cf0b882913da464a1e722a31fb44db35208663487efb7a3d8ed6",
"tensor_dtypes": [
"BF16"
"tensors": 174
"file": "model-00002-of-00003.safetensors",
"bytes": 3987450520,
"sha256": "0b48adbb1f60e901153d91907ba11ce63bd4b8b584482e730f48808d055dfba1",
"official_LFS_sha256": "0b48adbb1f60e901153d91907ba11ce63bd4b8b584482e730f48808d055dfba1",
"tensor_dtypes": [
"BF16"
"tensors": 219
"file": "model-00003-of-00003.safetensors",
"bytes": 99630640,
"sha256": "7dd39ccca5e4de123c74c14af44c9bf2eb75df33b4614382af0134528e060d5d",
"official_LFS_sha256": "7dd39ccca5e4de123c74c14af44c9bf2eb75df33b4614382af0134528e060d5d",
"tensor_dtypes": [
"BF16"
"tensors": 5
"runtime": {
"hardware": "Apple M1 Pro,16GB unified memory",
"python_version": "3.12.16 arm64",
"versions": {
"mlx": "0.32.4",
"mlx-metal": "0.32.4",
"mlx-lm": "0.32.2",
"transformers": "5.22.2",
"tokenizers": "0.23.3",
"huggingface-hub": "2.4.0",
"safetensors": "0.8.0",
"numpy": "2.5.4"
"sampler": {
"implementation": "mlx_lm.sample_utils.make_sampler",
"kwargs": {
"temp": 0.7,
"top_p": 0.8,
"top_k": 20,
"min_p": 0.0,
"min_tokens_to_keep": 1,
"xtc_probability": 0.0,
"xtc_threshold": 0.1
"order": "top_p on untempered logprobs, then top_k, then categorical sampling with temperature; actual MLX order, not claimed identical to Hailo or Transformers",
"logits_processors": [],
"repetition_penalty": 1.0,
"additive_frequency_penalty": 0.0,
"additive_presence_penalty": 0.0
"generation": {
"max_tokens": 512,
"prefill_step_size": 128,
"prompt_cache": "fresh make_prompt_cache per request",
"max_kv_size": null,
"kv_bits": null,
"draft_model": null,
"stop_strings": [],
"stop": "effective tokenizer EOS IDs only; length remains incomplete",
"seed": "mx.random.seed immediately before each request, local backend only"
"nominal_EOS_IDs": [
151643,
151645
"inputs": [
"input_id": "W54_EN_BASELINE",
"ordered_messages": [
"role": "user",
"content": "Explain why changing x does or does not change y.\n```python\nx = 2\ny = x + 3\nx = 9\nprint(y)\n```\n\nAt most two sentences. No headings or additional examples."
"input_id": "W54_FR_BASELINE",
"role": "user",
"content": "Explique pourquoi modifier x change ou ne change pas y.\n```python\nx = 2\ny = x + 3\nx = 9\nprint(y)\n```\n\nDeux phrases au maximum. Sans titres ni exemples supplémentaires."
"input_id": "W55_EN_BASELINE",
"role": "user",
"content": "Explain why changing x does or does not change y.\n```python\nx = 2\ny = x + 3\nx = 9\ny = x + 3\nprint(y)\n```\n\nAt most two sentences. No headings or additional examples."
"input_id": "W55_FR_BASELINE",
"role": "user",
"content": "Explique pourquoi modifier x change ou ne change pas y.\n```python\nx = 2\ny = x + 3\nx = 9\ny = x + 3\nprint(y)\n```\n\nDeux phrases au maximum. Sans titres ni exemples supplémentaires."
"results": [
"id": "W59_01",
"seed": 17,
"terminal": "stop",
"raw_UTF8": "Changing x does not change y because y is assigned the value of x + 3 at the time of assignment, and once y is set, it holds that value regardless of future changes to x. In this case, y remains 5 even after x is changed to 9.",
"raw_sha256": "816c943184731e77e4734125c05c0846acf99f722e2ecb701f438d5a49975fe6"
"id": "W59_02",
"seed": 17,
"terminal": "stop",
"raw_UTF8": "x est une variable locale, donc modifier x ne影响 pas y. \ny est calculé à partir de la valeur de x au moment de l'affectation, donc une modification ultérieure de x n'affecte pas la valeur de y.",
"raw_sha256": "f781333b8215401a6f8c33fc7bdc1015a7a6d224b5844cecbf3d0be3564dd4f9"
"id": "W59_03",
"seed": 17,
"terminal": "stop",
"raw_UTF8": "y est calculé une fois lorsque x vaut 2, puis reste constant. \nModifier x après cette affectation n'a aucun effet sur la valeur de y.",
"raw_sha256": "e338efc0c7070636113aff1765879fc8f1e9232ce463d39793a762c02c1376fe"
"id": "W59_04",
"seed": 17,
"terminal": "stop",
"raw_UTF8": "Changing x does not change y because y is assigned the value of x + 3 at the time of assignment, and after the first assignment, y is stored as 5. When x is later changed to 9, the value of y remains 5 since it was already computed and stored.",
"raw_sha256": "3cc7d27b1d887fb3586e88233a1b14545f6ea150541f8ca2b4457a782d73322d"
"id": "W59_05",
"seed": 29,
"terminal": "stop",
"raw_UTF8": "Changing x does not change y because y is assigned the value of x + 3 at the time of assignment, and after the first assignment, y is bound to 5. When x is later changed to 9, the value of y remains 5 since it was already computed and stored.",
"raw_sha256": "e0ffec7fbc50bc2ea7b9e2690ae0ed8c1d26b9216c35ee15edf68a67cdb97e19"
"id": "W59_06",
"seed": 29,
"terminal": "stop",
"raw_UTF8": "y est calculé une fois lorsque x vaut 2, puis ne dépend plus de la valeur ultérieure de x. \nC'est une affectation de valeur, donc modifier x après ne影响 pas y.",
"raw_sha256": "40cc71a96d2ba0cd0591c3c6ab3ff9d75fc428050c43c3f440bcc98b78daa89c"
"id": "W59_07",
"seed": 29,
"terminal": "stop",
"raw_UTF8": "Lorsqu'on modifie `x`, `y` ne change pas car `y` est un objet qui référence la valeur de `x + 3` à un moment donné, et cette valeur est stockée dans une variable distincte. Une fois `y` affecté, il reste constant même si `x` change plus tard.",
"raw_sha256": "96635fcdcacdd6361b8f6b8959b959e6cd67720b5fcd26049c6c06439e399a78"
"id": "W59_08",
"seed": 29,
"terminal": "stop",
"raw_UTF8": "Changing x does not change y because y is assigned the value of x + 3 at the time of assignment, and after that, y is only a fixed result based on the original value of x. Once y is computed, it remains unchanged regardless of future modifications to x.",
"raw_sha256": "b4ab117fe09b6c0a516b5d73358a5a8fe3258b91d9205d17d09529da73748577"
"id": "W59_09",
"seed": 43,
"terminal": "stop",
"raw_UTF8": "y dépend de la valeur de x à l'heure de son calcul, mais une fois initialisé, y reste constant. \nModifier x après l'affectation de y n'a aucun effet sur sa valeur.",
"raw_sha256": "c351835a4200408f940d630e447008a30d73159427fdb33f3aeff165f550ec32"
"id": "W59_10",
"seed": 43,
"terminal": "stop",
"id": "W59_11",
"seed": 43,
"terminal": "stop",
"raw_UTF8": "Changing x does not change y because y is assigned the value of x + 3 at the time of assignment, and after that, y is only a fixed value based on the original x. When x is later changed to 9, y remains unchanged since it was already calculated and stored.",
"raw_sha256": "d57186e0b4fdb3ad260b366b88736a3476eb9ce82f579ff235e55022b07907b1"
"id": "W59_12",
"seed": 43,
"terminal": "stop",
"raw_UTF8": "x est une variable locale, donc modifier x ne影响 pas y. \ny est calculé à partir de la valeur de x à l'heure de l'assignation, donc une modification de x après ne change pas y.",
"raw_sha256": "37b0b8ed7fd09ce41bde00d57d41fa13ee83f2b4906a7610ce9442b29e8306e5"
"summary": [
"language": "en",
"attempts": 3,
"technical_complete": 3,
"content_no_material_defect": 3,
"material_content_errors": 0,
"requested_language_retained": 3,
"brevity_compliant": 3
"language": "fr",
"attempts": 3,
"requested_language_retained": 2,
"language": "en",
"attempts": 3,
"content_no_material_defect": 0,
"material_content_errors": 3,
"language": "fr",
"attempts": 3,
"requested_language_retained": 1,
"limits": [
"Nominal reference; exact HEF source revision remains unconfirmed.",
"Exposed-case engineering counts, not reliability or paired source-HEF estimates.",
"Native Hailo token IDs are unavailable; no native impossible-token claim."
