QtOpencv a small program to take out pictures from a mp4 file and save for later use in the model/ image
For users that are making there own model this small program can bee useful.
Check it out on GitHub - k-madsenDK/QtOpencv: simpel program to take a mp4 file combined with a hailo generated text fil and if needed save frames from the video file as jpg with the originale frame
I have updated the repos. There is now a opportunity to compare to hailo generated txt files. This can be used to see difference between to hef builds.
Sry i forget to update the CmakeFile.txt
The file can be used on ubuntu 24.04 by using the same apt install command as on the rpi 5
Dont use QtCreator on ubuntu just cmake . and then make
