python basic_pipelines/detection.py fails: No such file "resources/detection0.mp4"
python basic_pipelines/detection.py --input resources/detection0.mp4
Loading environment variables from /home/jlathrop/Documents/github/hailo-rpi5-examples/.env…
:white_check_mark: All required environment variables loaded.
Auto-detected Hailo architecture: hailo8
filesrc location=“resources/detection0.mp4” name=source ! queue name=source_queue_decode leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! decodebin name=source_decodebin ! queue name=source_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale name=source_videoscale n-threads=2 ! queue name=source_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 name=source_convert qos=false ! video/x-raw, pixel-aspect-ratio=1/1, format=RGB, width=1280, height=720 ! videorate name=source_videorate ! capsfilter name=source_fps_caps caps=“video/x-raw, framerate=30/1” ! queue name=inference_wrapper_input_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailocropper name=inference_wrapper_crop so-path=/usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes/cropping_algorithms/libwhole_buffer.so function-name=create_crops use-letterbox=true resize-method=inter-area internal-offset=true hailoaggregator name=inference_wrapper_agg inference_wrapper_crop. ! queue name=inference_wrapper_bypass_q leaky=no max-size-buffers=20 max-size-bytes=0 max-size-time=0 ! inference_wrapper_agg.sink_0 inference_wrapper_crop. ! queue name=inference_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale name=inference_videoscale n-threads=2 qos=false ! queue name=inference_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! video/x-raw, pixel-aspect-ratio=1/1 ! videoconvert name=inference_videoconvert n-threads=2 ! queue name=inference_hailonet_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailonet name=inference_hailonet hef-path=/usr/local/hailo/resources/models/hailo8/yolov8m.hef batch-size=2 vdevice-group-id=1 nms-score-threshold=0.3 nms-iou-threshold=0.45 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 force-writable=true ! queue name=inference_hailofilter_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailofilter name=inference_hailofilter so-path=/usr/local/hailo/resources/so/libyolo_hailortpp_postprocess.so function-name=filter_letterbox qos=false ! queue name=inference_output_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! inference_wrapper_agg.sink_1 inference_wrapper_agg. ! queue name=inference_wrapper_output_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailotracker name=hailo_tracker class-id=1 kalman-dist-thr=0.8 iou-thr=0.9 init-iou-thr=0.7 keep-new-frames=2 keep-tracked-frames=15 keep-lost-frames=2 keep-past-metadata=False qos=False ! queue name=hailo_tracker_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! queue name=identity_callback_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! identity name=identity_callback ! queue name=hailo_display_overlay_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailooverlay name=hailo_display_overlay ! queue name=hailo_display_videoconvert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert name=hailo_display_videoconvert n-threads=2 qos=false ! queue name=hailo_display_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! fpsdisplaysink name=hailo_display video-sink=autovideosink sync=true text-overlay=False signal-fps-measurements=true
Error: gst-resource-error-quark: Resource not found. (3), ../plugins/elements/gstfilesrc.c(553): gst_file_src_start (): /GstPipeline:pipeline0/GstFileSrc:source:
No such file “resources/detection0.mp4”
Shutting down… Hit Ctrl-C again to force quit.
Exiting with error…
Hi @user524 ,
Please try without input argument to use our default video file.
Alternatively, you can look into /usr/local/hailo/resources for a full path of exiting video files and to put there if you will your files.
