Processing live video stream from opencv on raspberry pi 5
I can’t process frames from the web camera via hailo 8 on raspberry pi 5. The web camera itself works, I checked it via qv4l2. I get a segmentation fault error when calling the get_roi_from_buffer function
if name == “main”:
#app.run()
cap = cv2.VideoCapture(0)
while True:
    ret, frame = cap.read()
    frame = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
    frame = frame.astype('uint8')
    roi = hailo.get_roi_from_buffer(frame) # error: segmentation fault
    cv2.imshow('frame', frame)
    if cv2.waitKey(1) == ord('q'):
        break
Hey @sherinkonstantiv,
Welcome to the Hailo Community! Great to have you here.
Regarding the segmentation fault you’re encountering, it’s important to note that the Hailo Raspberry Pi 5 examples are specifically designed to work with GStreamer pipelines for handling video streams. When you use OpenCV’s cv2.VideoCapture, the frames are processed as NumPy arrays, which are not compatible with Hailo’s hailo.get_roi_from_buffer() function. On the other hand, GStreamer pipelines provide Gst.Buffer objects that integrate seamlessly with the Hailo Raspberry Pi 5 examples.
To address this issue, you have two potential solutions:
  1. Use our GStreamer-based app and extract the frames from GStreamer. You can find an example of this approach in our Hailo Raspberry Pi 5 examples repository: GitHub - hailo-ai/hailo-rpi5-examples
  2. Alternatively, you can use our Python-based example, which you can find in the Hailo Application Code Examples repository: Hailo-Application-Code-Examples/runtime/python at main · hailo-ai/Hailo-Application-Code-Examples · GitHub
Both of these options should help you resolve the segmentation fault and enable you to successfully process video streams using the Hailo Raspberry Pi 5.
Let me know if you have any further questions or need additional assistance!
Best Regards,
Omria
Hi @sherinkonstantiv,
We developed a python SDK that makes working with Hailo8/Hailo8L easy. You find instructions and tutorials at: DeGirum/hailo_examples.
For your specific issue, our PySDK code looks as below. The code runs a yolov8n model on WebCam with index 0. If you have HAILO8 device instead of HAILO8L, just change model_name=yolov8n_relu6_coco--640x640_quant_hailort_hailo8_1
model_name = "yolov8n_relu6_coco--640x640_quant_hailort_hailo8l_1"
video_source = 0
# load AI model
model = dg.load_model(
    model_name=model_name,
    zoo_url=zoo_url,
    token=token
# Run inference on video_source
with degirum_tools.Display("AI Camera") as output_display:
    for inference_result in degirum_tools.predict_stream(model, video_source):
        output_display.show(inference_result)
Please let u sknow if this helps or if you encounter any difficulties in running the above code.
Hi @shashi,
I have tried these solutions and they work great locally with image and video sources, but I can’t make it work with Picamera. I have a Raspberry Pi 5 with an AI Kit (Hailo8L) and a connected Arducam. I can run a simple Picamera2 script to capture and display images, so I am certain that the camera index is 0.
I tried to run the following code:
import degirum_tools
import cv2
from picamera2 import Picamera2
import time
face_det_model_name = "scrfd_500m--640x640_quant_hailort_hailo8l_1"
zoo_url = "/home/pi/degirum/scrfd_500m--640x640_quant_hailort_hailo8l_1"
image_source = "Friends1.jpg"
video_source = "faces_and_gender.mp4"
camera_source = 0
token = ''
    model_name=face_det_model_name,
    zoo_url=zoo_url,
    token=token,
    overlay_color=(0, 255, 0)  # Green color for bounding boxes
with degirum_tools.Display("display") as display:
    for res in degirum_tools.predict_stream(model, camera_source):
        display.show(res)
I am getting the following error:
degirum.exceptions.DegirumException: Fail to capture camera frame. May be camera was opened by another notebook?
  File "/home/pi/degirum/face_detection.py", line 28, in <module>
  File "/home/pi/degirum/degirum_env/lib/python3.11/site-packages/degirum_tools/inference_support.py", line 224, in predict_stream
    for res in model.predict_batch(video_source(stream, fps=fps)):
  File "/home/pi/degirum/degirum_env/lib/python3.11/site-packages/degirum/model.py", line 288, in predict_batch
    for res in self._predict_impl(source):
  File "/home/pi/degirum/degirum_env/lib/python3.11/site-packages/degirum/model.py", line 1249, in _predict_impl
    raise DegirumException(
degirum.exceptions.DegirumException: Failed to perform model 'scrfd_500m--640x640_quant_hailort_hailo8l_1' inference: Fail to capture camera frame. May be camera was opened by another notebook?
Can you help me?
Hi @Szymon_Parol
camera_source=0 means a web camera attached and not a raspberry pi camera. You can define a generator function that gets frames from picamera and pass it to predict function. Please let me know if you need further help.
@Szymon_Parol
Can you please try this code and let me know if it works?
import cv2
# Define a frame generator: a function that yields frames from the Picamera2
def frame_generator():
    picam2 = Picamera2()
    # Configure the camera (optional: set the resolution or other settings)
    picam2.configure(picam2.create_preview_configuration())
    # Start the camera
    picam2.start()
    try:
        while True:
            # Capture a frame as a numpy array
            # Yield the frame
            yield frame
    finally:
        picam2.stop()  # Stop the camera when the generator is closed
# Define model parameters (replace these with your own values)
token = ''
# Load the object detection AI model from the model zoo
    zoo_url=zoo_url,
    token=token,
# Process the video stream by AI model using model.predict_batch():
for result in model.predict_batch(frame_generator()):
    # Display the frame with AI annotations in a window named 'AI Inference'
    cv2.imshow("AI Inference", result.image_overlay)
    # Process GUI events and break the loop if 'q' key was pressed
    if cv2.waitKey(1) & 0xFF == ord("q"):
        break
# Destroy any remaining OpenCV windows after the loop finishes
cv2.destroyAllWindows()
@shashi
Thank you very much. It worked! I only added {‘format’: ‘RGB888’} as an argument to picam2.create_preview_configuration because Picamera2 returns 4-channel images by default.
I will add the whole code in case someone needs it.
import cv2
    picam2.configure(picam2.create_preview_configuration({'format': 'RGB888'}))
    # Start the camera
    picam2.start()
    try:
        while True:
            # Yield the frame
            yield frame
    finally:
token = ''
    zoo_url=zoo_url,
    token=token,
        break
@Szymon_Parol
Nice. It would be a very good example code for the community to have.
Thanks for those details, that was very helpful.
Is there a way to implement Degirum tools object tracker into the model predict batch?
Object tracker and zone detection…
@victor and @mamba8
Please see this for tracking: hailo_examples/examples/object_tracking.ipynb at main · DeGirum/hailo_examples
My confusion is that the object tracking example uses degirum_tools predict stream:
with degirum_tools.Display(“AI Camera”) as output_display:
Whereas in the picamera example we are using model predict batch without degirum_tools.
I’m still going through your user guides to do with Hailo and PySDK, so bare with me.
Hi @mamba8
predict_stream is just a convenient wrapper that supports web camera, video file, rtsp stream. You can use predict_batch for pi camera and rest of the code remains the same.
What I have done is attach the object tracker to the model but the output doesn’t show the tracking.
degirum_tools.attach_analyzers(model, [tracker])
results = model.predict_batch(frame_generator())
for result in results:
output_display.show(result)
I still see original detection but no tracking boxes or tracking lines.
Thanks!
I’ve also tried the cv2.imshow with result.image_overlay
@mamba8
Can you share the full code? Maybe you are filtering classes to be tracked?
That was it! I had a typo in the class_list in the tracker.
Thank you so much for the prompt replies and help getting this resolved.
@mamba8
Glad to hear you got it to work. Please feel free to let us know if you need any further clarifications/support.
Hello @shashi , Thank you for the link related to Object Tracking.
But is there any documentation where we can read more about the degirum_tools and ObjectTracker please ?
@AKSHAY_KUMAR
We are working on degirum_tools documentation now but it will not be available until mid-March. In the meantime, please let us know if you need any clarifications. The implementation is pretty standard. Our main contribution was to pipeline tracker in an easy-to-use way.
