Piper-tts 1.4.0: "TTS synthesis/playback failed: # channels not specified"
piper-tts 1.4.0: “TTS synthesis/playback failed: # channels not specified”
The Error
After upgrading piper-tts to version 1.4.0, you may see this error when using text-to-speech:
ERROR | TTS synthesis/playback failed: # channels not specified
NOTE: This can also be installed automatically if the specific version is not defined in pyproject.toml (Currently it is not).
Check your version by running this command after sourcing setup_env.sh
pip list | grep piper-tts
Why This Happens
This error comes from Python’s wave module when trying to write audio data to a WAV file without first setting the number of audio channels.
In piper-tts 1.4.0, the synthesize() method added a new check that skips empty phoneme lists:
for phonemes in sentence_phonemes:
    if not phonemes:
        continue  # <-- Added in v1.4.0
When certain text inputs result in empty phonemes, no audio chunks are generated. This causes synthesize_wav() to never set the WAV file format (channels, sample rate, sample width), and Python’s wave module raises:
wave.Error: # channels not specified
Additional Issues with 1.4.0
piper-tts 1.4.0 is not backwards compatible. It changed from a self-contained platform-specific wheel to a pure Python package that requires additional system dependencies:
  • v1.3.0: Includes bundled espeakbridge.so native library and espeak-ng-data/ (~13.8 MB wheel)
  • v1.4.0: Pure Python - requires you to install espeak-ng system-wide
If you try to use 1.4.0 without the system dependencies, you’ll also see:
ImportError: cannot import name 'espeakbridge' from 'piper'
The Fix: Downgrade to 1.3.0
The fastest and most reliable solution is to downgrade to piper-tts 1.3.0, which works out of the box without additional system dependencies.
Step 1: Update your dependencies file
# pyproject.toml
"piper-tts==1.3.0",
or
# requirements.txt
piper-tts==1.3.0
Step 2: Downgrade the package
pip install piper-tts==1.3.0
Summary
Version Status Notes
1.3.0 :white_check_mark: Recommended Self-contained, works out of the box
1.4.0 :warning: Breaking changes Requires system espeak-ng, has phoneme handling bugs
