I’m trying to create a pipeline string that will display to the video sink and also send the video out via an rtsp port on the raspberry pi.
How would I modify this pipeline string?
pipeline_string = (
"hailomuxer name=hmux "
+ source_element
+ "tee name=t ! "
+ QUEUE("bypass_queue", max_size_buffers=20)
+ "hmux.sink_0 "
+ "t. ! "
+ QUEUE("queue_hailonet")
+ "videoconvert n-threads=3 ! "
f"hailonet hef-path={self.hef_path} batch-size={self.batch_size} {self.thresholds_str} force-writable=true ! "
+ QUEUE("queue_hailofilter")
+ f"hailofilter so-path={self.default_postprocess_so} {self.labels_config} qos=false ! "
+ QUEUE("queue_hmuc")
+ "hmux.sink_1 "
+ "hmux. ! "
+ QUEUE("queue_hailo_python")
+ QUEUE("queue_user_callback")
+ "identity name=identity_callback ! "
+ QUEUE("queue_hailooverlay")
+ "hailooverlay ! "
+ QUEUE("queue_videoconvert")
+ "videoconvert n-threads=3 qos=false ! "
+ QUEUE("queue_hailo_display")
+ f"fpsdisplaysink video-sink={self.video_sink} name=hailo_display sync={self.sync} text-overlay={self.options_menu.show_fps} signal-fps-measurements=true "
omria
Hey @andy.froncioni
You might try something like this:
pipeline_string = (
+ source_element
+ "tee name=t ! "
+ "hmux.sink_0 "
+ "t. ! "
+ "hmux.sink_1 "
+ "hmux. ! "
+ "hailooverlay ! "
+ "tee name=output_tee ! " # Add a tee after hailooverlay
+ "output_tee. ! " # Branch for RTSP stream
+ QUEUE("queue_rtsp")
+ "videoconvert ! video/x-raw,format=I420 ! "
+ "x264enc tune=zerolatency bitrate=500 speed-preset=superfast ! "
+ "rtph264pay config-interval=1 pt=96 ! "
+ "udpsink host=127.0.0.1 port=8554"
Key Changes:
- Added a new
tee element named output_tee after the hailooverlay element.
- The original video sink branch is mostly unchanged and connected to one branch of
output_tee.
- Created a new branch from
output_tee for the RTSP stream, which includes:
- Queue for buffering
videoconvert for format compatibility
x264enc for H.264 encoding with low-latency settings
rtph264pay for RTP packetization
udpsink to stream the video to localhost on port 8554.
This setup should help you achieve the dual output to both the video sink and RTSP stream.
Thank you for your help.
However, I looked for a difference with your solution, but I think you might’ve copy-pasted the original pipeline string.
omria
4
Yeah you’re correct , Updated it .
Thank you for this! It de-mystified a few things in my understanding.
