PaddleOCR Text Detection + Recognition:
This guide provides a high-level overview of the newly added PaddleOCR application, focusing into the internal structure and advanced functionality, the app performs end-to-end text recognition using a two-stage OCR pipeline accelerated by Hailo-8 and Hailo-10H devices.
The pipeline combines:
  • A text detector to locate text regions
  • A text recognizer to decode the text inside each region
Example Runs
Single Image:
Folder of Images:
python3 paddle_ocr.py -n ocr_det.hef ocr.hef -i ./my_images/
Video File:
python3 paddle_ocr.py -n ocr_det.hef ocr.hef -i input.mp4
Camera:
python3 paddle_ocr.py -n ocr_det.hef ocr.hef -i camera
Optional: Spell Correction
You can optionally improve OCR text accuracy using a spelling correction dictionary powered by symspellpy
python3 paddle_ocr.py … --use-corrector
Full Pipeline Description
The PaddleOCR app uses a multi-threaded, queue-based pipeline to process input efficiently and asynchronously across multiple stages.
Preprocessing
Text Detector (HEF 1)
Detection Postprocess → [No Text] → Visualize
Text Recognizer (HEF 2)
OCR Postprocess
Visualization
   ↓ [Output]
1. Preprocessing
  • Input source can be:
    • A single image
    • A folder of images
    • A video file
    • A live camera stream
  • Each frame is:
    • Resized and padded to fit the detector’s input size (while preserving aspect ratio)
    • Batched (if batch_size > 1)
  • Outputs:
    • input_frame (for visualization)
    • preprocessed_frame (ready for inference)
  • Sent to: detector_hailo_infer via det_input_queue
2. Text Detection (HEF 1)
  • Uses the first HEF model to detect text regions
  • Runs asynchronously using HailoInfer.run()
  • On inference completion, triggers a callback:
    • Packs (original_frame, raw_output_tensor)
  • Sent to: det_postprocess_queue
3. Detection Postprocessing
  • Converts the raw heatmap into bounding boxes using DBPostProcess
  • For each box:
    • Crops the region from the original frame
    • Resizes it to fit the OCR model’s expected input size (with padding)
    • Attaches metadata: frame ID and box location
  • If no boxes are detected:
    • Sends the original frame with empty OCR results directly to visualization
  • Otherwise:
    • Sends: (frame, [resized_crop], (frame_id, box)) to ocr_input_queue
4. Text Recognition (HEF 2)
  • Uses the second HEF model to recognize text in each cropped region
  • Also runs asynchronously using HailoInfer.run()
  • On completion, a callback sends:
    • (frame_id, original_frame, ocr_result, box) to ocr_postprocess_queue
5. OCR Postprocessing
  • Collects all OCR outputs for a given frame (tracked by frame_id)
  • Keeps track of how many boxes are expected for that frame
  • Once all OCR results are collected:
    • Groups them into one bundle: (frame, list_of_results, list_of_boxes)
    • Sends to: vis_output_queue for visualization
  • Cleans up memory (removes processed frame_id entries)
6. Visualization & Rendering
  • Uses the inference_result_handler() to:
    • Decode OCR model outputs into readable text
    • (Optionally) apply spell correction using SymSpell if --use-corrector is set
  • Draws the results:
    • Left side: original image
    • Right side: same image with OCR results written inside white boxes
  • Saves each frame (image/video) to --output-dir
  • Optionally displays FPS if --show-fps is enabled
Threads Overview
Each of these stages runs in a separate thread:
Thread Role
preprocess_thread Prepares and resizes input
det_thread Runs text detection HEF
detection_postprocess Extracts boxes, crops, resizes
ocr_thread Runs text recognition HEF
ocr_postprocess Groups and synchronizes OCR results
vis_postprocess Handles decoding, correction, and rendering
Internal Queues
Queue Name Purpose
det_input_queue Holds original + preprocessed frames for the detector inference engine
det_postprocess_queue Receives detection outputs (raw tensors + original frames) for postprocessing
ocr_input_queue Carries cropped text regions + metadata to the OCR inference engine
ocr_postprocess_queue Receives OCR model outputs along with original frame and box info
vis_output_queue Collects final grouped results (frame, texts, boxes) for visualization and output
Hi @Majed_Abu_Mokh
Is there a github repo or a shared folder that contains these hef models?
hey @shashi,
The example includes a bash script for downloading the relevant HEF files (download_resources.sh)
@Marina_Vilela_Bento
Thanks. For some reason, I could not see the link to the github repo when I posted my message.
Hi @Majed_Abu_Mokh , do you have models for Hailo8l ?
Hi Aleksei_Markov
I don’t have models for Hailo-8L at the moment.
I’ll update you as soon as they’re released.
Do you happen to know which PaddleOCR version the .hef file is based off? I am also curious about the compilation process to .hef, how did you split off the detection and character recognition parts?
