Hailo-8 AI HAT repo.hailo.ai down? Cannot install hailort or hailo-all on Raspberry Pi 5 – DNS failure
I just did a test install and everything works as expected. I did the following:
- Burn an SD card with Raspberry Pi OS 64-bit Full port of Debian Bookworm
based on the following guide
Raspberry Pi - Documentation - AI HAT+
I run the following commands to install all components
sudo apt update
sudo apt upgrade
sudo apt install dkms
sudo apt install hailo-all
sudo reboot
After reboot I run the following command to verify the Hailo device was visible in the OS.
lspci
Then I confirmed that HailoRT can access the device by running:
If you have further issue, please provide some more detailed information of what you have tried and the error message you are seeing.
