NanoTrack Head ONNX Export → Hailo Parser & Quantization Errors (Unexpected zero dimension, Conv3D integer division)
  1. Model: NanoTrack (Siamese tracker, MobileNetV3 backbone, BAN head)
  2. Head type: DepthwiseBAN (ban_v2.py)
  3. Checkpoint: nanotrackv2.pth (48-channel version)
  4. Config: BAN.TYPE = DepthwiseBAN (configv2.yaml)
  5. Exported with: PyTorch 1.13.1 → ONNX opset 14
  6. Target HW: Hailo-8L
  7. SDK Versions:
    • Hailo DFC 3.29.0
    • HailoRT 4.19.0
      I’m trying to run the NanoTrack head (DepthwiseBAN, MobileNetV3 backbone) on Hailo-8L.
      • ONNX export works fine.
      • Hailo parser runs successfully and produces a .har.
      • The problem appears during optimization/quantization with calibration data.
      Errors I see:
      1. "float32 is not a valid CalibrationDataType"
      2. integer division or modulo by zero inside Conv3DOp, log snippet:
        kernel shape: (1, 2, 2, 64), input feature: 16, groups: 64
        kernel shape 3: 64
        Exception encountered when calling layer 'conv_op' (type Conv3DOp).
      It looks like some depthwise conv layers in the BAN head are being mapped to Conv3DOp and break during quantization.
      Questions:
      • Is this a known limitation or bug in Hailo SDK with grouped/depthwise conv?
      • How should I fix the CalibrationDataType issue (is a different format expected)?
      • Is there a recommended way to restructure these layers so the head becomes Hailo-compatible?
      Thanks for any guidance!
