I’d like to run the VLM Moondream on a RPI5 with the AI KIT (13 TOPS).
I was wondering if it is possible to use the Hailo accelerator to partially run some of the workflow. For example, would it be possible to run the image encoder on the Hailo accelerator? I found that something similar was done for hailo-CLIP
I would appreciate any suggestions or guidance.
Thanks
