I would like to know the modelscript.alls used to optimize and compile segformer b0 for Hailo8, the model on HailoModelZoo under segmentation models.
Here is more details of the model
https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v2.18.0/hailo8/segformer_b0_bn_profiler_results_compiled.html#/model-details
Here is the modelscript files I am using based on what I could understand from model details
normalization199 = normalization([ 123.675, 116.28, 103.53], [58.395, 57.12, 57.375])
model_optimization_flavor(optimization_level=2,compression_level=0)
model_optimization_config(calibration, batch_size=2, calibset_size=64)
context_switch_param(mode=allowed)
allocator_param(timeout=15h)
As input I am using segformer_b0_512x1024.onnx file available on model zoo repo and I also know that there was another post where the user managed to compile it by resizing it down, but according to model zoo info dev team from Hailo did not had to resize.
I am using hailo dfc 3.28 and as far as I understand this model was compiled on hailo dataflow compiler 2.18
Compilation fails on trying to map the Context 12/12
One of the outputs I got(this was with timeout=3h but with timeout=15h also it failed on the same way)
[warning] Failed recording best-effort buffers: l4_portal_from_resize3_d0_to_resize3_dc was not found in toposort recipe during buffers override record [error] Mapping Failed (Timeout, allocation time: 3h 19m 11s) [error] Mapping Failed (Timeout, allocation time: 3h 19m 11s) Resolver didn’t find possible solution. Watchdog expired after 3h 0m 2s Mapping Failed (Timeout, allocation time: 3h 19m 11s) [error] Failed to produce compiled graph .
So could someone share modelscript.alls used for this model in particular ?
