Modell with 2 Inputs using python class HailoInfer
Hi.
I’m new on Hailo and I have some trouble. I started with de Hailo_app / Python / standalone_apps and so far so good.
Now I created a simple ONNX - Modell for calculating the mean of to images, builded the href and tryed do write a Python script for inference, but i’m runing in trouble, because it seem’s that the class HailoInfer didn’t support more than one Input …
Any help ?
Hi @Armin_71,
Can you please share the code you’re trying to use?
Hi Michael,
this is my code:
from hailo_inference import HailoInfer
net = “/home/armin/hailo_compile/testadd.hef”
#the parameter input_type cause an error
#hailo_inference = HailoInfer(hef_path = net,batch_size=1, input_type=“FLOAT32”, output_type=“FLOAT32”)
hailo_inference = HailoInfer(hef_path = net,batch_size=1, output_type=“FLOAT32”)
#here I get the shape only from one input
dest_hh, dest_ww, _ = hailo_inference.get_input_shape()
random_input1 = np.random.rand([256,256,3]).astype(np.float32)
random_input2 = np.random.rand(
input_batch = [
“testadd/input_layer1”: random_input1,
“testadd/input_layer2”: random_input2
output_queue = queue.Queue(10)
inference_callback_fn = partial(
inference_callback,
input_batch=input_batch,
output_queue=output_queue
#here I get another error
job = hailo_inference.run(input_batch, inference_callback_fn)
regards
Armin
Hi @Armin_71,
The HailoInfer wrapper class in hailo_apps was designed as a convenience for single-input models, so it doesn’t handle multi-input HEFs out of the box. For models with multiple inputs, you might want to use the lower-level hailo_platform InferModel API directly, which does support addressing each input by name via .input("layer_name").
You can find the relevant Python async inference tutorial and API reference here: v5.2.0 | Hailo.
You might also find it helpful to run hailortcli parse-hef testadd.hef to verify the exact input layer names your HEF expects.
Michael.
