I’m currently setting up the environment to convert a custom ONNX model to a HEF file using Hailo’s SDK and Model Zoo.
Here’s what I’ve done so far:
- Downloaded and installed the following from the official Hailo website:
hailort-4.21.0-cp310-cp310-linux_x86_64.whlhailort-pcie-driver_4.21.0_all.deb
- Successfully installed the PCIe driver using DKMS.
- Cloned the
hailo_model_zoorepository and attempted to parse my ONNX model (crosswalk_dotted_best.onnx) usingmain.py.
However, I’m consistently encountering the following error:
Additionally, this module (and hailo_platform) is not found anywhere in the installed packages or under the hailo_ai_sw_suite directory:
python3 -c "import hailo_sdk_client"
# → ModuleNotFoundError: No module named 'hailo_sdk_client'
find ~/hailo_ai_sw_suite -type d -name "hailo_sdk_client"
# → (no results)
Request:
Could you please advise where to obtain a .whl or .run package that includes hailo_sdk_client and hailo_platform?
Alternatively, is there an official Python environment or Docker image that contains the full SDK (with compiler and client modules) required for ONNX-to-HEF conversion?
Environment:
OS: Ubuntu 22.04
Python: 3.10.12
Hailo SDK: 4.21.0
Objective: Convert a YOLOv5-based ONNX model to a HEF file for deployment on Hailo-8.
Thank you in advance for your support.
