Hello there,
I have worked to optimize PointPillars model (without voxel and middle encoders) with ClientRunner.optimize and 300 calibration data (with a data shape of [300, 496, 432, 64]). While this calibration working without issues, I have a concern with the calibration progress bar, which runs to only 64 that is the last dimension of my calibration data.
My question is this calibration works correctly or it mistook the last dimension as the batch size? Any recommendations to fix this issue? I attached my code and logs as below.
Code:
import os
import glob
import onnx
# from hailo_sdk_client.exposed_definitions import Dims
if __name__ == '__main__':
onnx_dir = 'pointpillars_without_mid.onnx'
hailo_dir = '/local/workspace/pointpillars_without_mid.har'
calib_dir = 'calib_data1000'
n_calib = 300
onnx_dir = os.path.expanduser(onnx_dir)
hailo_dir = os.path.expanduser(hailo_dir)
calib_dir = os.path.expanduser(calib_dir)
onnx.checker.check_model(onnx_dir, full_check=True)
runner = ClientRunner(hw_arch='hailo8')
onnx_dir,
'pointpillars_without_mid',
start_node_names=['x'],
end_node_names=['cls_score', 'bbox_pred', 'dir_cls_preds'],
net_input_shapes={'x': [1, 64, 496, 432]},
# NOTE: not works
# net_input_format=[Dims.BATCH, Dims.HEIGHT, Dims.WIDTH, Dims.CHANNELS],
calib_files = glob.glob(f'{calib_dir}/*')
calib_data = []
for idx, calib_file in enumerate(calib_files):
# data: [1, 64, 496, 432]
data = np.load(calib_file)
calib_data.append(data)
if idx >= n_calib + 1:
break
# calib_data: [n_calib, 64, 496, 432]
calib_data = np.concatenate(calib_data, axis=0)
# calib_data: [n_calib, 496, 432, 64]
# NOTE: without this transpose will cause shape errors.
calib_data = np.transpose(calib_data, (0, 2, 3, 1))
runner.optimize(calib_data)
runner.save_har(hailo_dir)
Log:
(hailo_virtualenv) hailo@docker-desktop:/local/workspace$ python parse_onnx_pointpillars.py [info] No GPU chosen and no suitable GPU found, falling back to CPU.
[info] Translation started on ONNX model pointpillars_without_mid
[info] Restored ONNX model pointpillars_without_mid (completion time: 00:00:00.05)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.16)
[info] Start nodes mapped from original model: 'x': 'pointpillars_without_mid/input_layer1'.
[info] End nodes mapped from original model: '/bbox_head/conv_cls/Conv', '/bbox_head/conv_reg/Conv', '/bbox_head/conv_dir_cls/Conv'.
[info] Translation completed on ONNX model pointpillars_without_mid (completion time: 00:00:00.63)
[warning] Reducing optimization level to 0 (the accuracy won't be optimized and compression won't be used) because there's less data than the recommended amount (1024), and there's no available GPU
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.06)
Calibration: 100%|βββββββββββββββββββββββββββββββββββββββββββββββββββ| 64/64 [02:24<00:00, 2.25s/entries]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:02:24.44)
[info] No shifts available for layer pointpillars_without_mid/conv15/conv_op, using max shift instead. delta=0.2158
[info] No shifts available for layer pointpillars_without_mid/conv15/conv_op, using max shift instead. delta=0.1079
[info] No shifts available for layer pointpillars_without_mid/conv16/conv_op, using max shift instead. delta=0.4556
[info] No shifts available for layer pointpillars_without_mid/conv16/conv_op, using max shift instead. delta=0.2278
[info] Adaround skipped
[info] Saved HAR to: /local/workspace/pointpillars_without_mid.har
[info] Restored ONNX model pointpillars_without_mid (completion time: 00:00:00.04)
[info] Translation completed on ONNX model pointpillars_without_mid (completion time: 00:00:00.66)
Calibration: 100%|βββββββββββββββββββββββββββββββββββββββββββββββββββ| 64/64 [02:25<00:00, 2.28s/entries]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:02:25.78)
