Lightweight HailoRT bindings in Nim – simple, fast inference without Python or CMake
I’ve been working with HailoRT and felt that:
  • Python bindings are convenient but sometimes too heavy
  • C++ works but build setup (CMake, etc.) can get painful
  • Simple inference requires quite a bit of boilerplate
So I built a minimal Nim binding + high-level Detector API.
Example:
import hailort_nim
let det = Detector.open(“model.hef”).get
let res = det.detectNmsByClass(input).get
for d in res:
  echo d.classId, " ", d.score
It uses Futhark to generate bindings from the C API, so no manual wrapping.
Tested with YOLOv11s HEF models, including NMS parsing.
Repo: GitHub - centurysys/hailort_nim: Minimal and fast Nim bindings for HailoRT with a simple Detector API · GitHub
Performance
Tested on AM67A (Cortex-A53 1.4GHz), single inference:
Python:
real    1.592s
user    1.389s
sys     0.361s
Nim:
real    0.465s
user    0.075s
sys     0.308s
In this setup, Python spends most time in user-space processing,
while Nim is mostly bound by device I/O.
(~3x faster in this simple test)
Would love feedback, especially from people who tried Python/C++ approaches.
Thanks @Takeyoshi_Kikuchi for sharing this useful project - We appreciate it!
I’ve been working on improving my hailort_nim bindings and wanted to share an update.
Recent changes:
  • Multi-HEF support using openPrepared / activate / deactivate
    → allows multiple models to stay loaded and switch with low overhead (~2–3 ms activate)
  • Device status APIs (temperature, throttling)
  • Power measurement is now handled as optional since it’s not supported on all boards
  • Fixed a critical ownership issue where physical devices from vdevice were incorrectly released,
    which could lead to segmentation faults
This makes the library much more stable for long-running applications.
Repo:
Feedback is welcome!
Thanks @Takeyoshi_Kikuchi !
