License hailo zoo models
I want to ask about license for model usage.
I can see that the repository hailo_model_zoo is on MIT license, does it mean that all the model that are available there are on MIT as well, and I can use them in my projects?
If not can you share the list of licenses per model, plz?
Regards,
Hi @user568 ,
In general, most models in the Model Zoo are not owned by Hailo, so any question about their license should be sent to the model’s owner/creator. We are only compiling them for Hailo. The MZ webpage states, next to each model, what its license is.
If you plan to use a model, you need to comply with the license requirements, and keep in mind that licensing requirements can vary depending on how it’s integrated. It’s always a good idea to check with your legal team to make sure everything is covered.
I see thanks you :slight_smile:
Have a good day.
