Lane Detection example questions
I came across an interesting example of a lane detection model in this repository:
I’ve searched extensively for more information or details but haven’t found anything useful. The example uses a .hef model compiled for the HAILO-8 device. Where can I find a model suitable for the HAILO-8L device?
I noticed that the example is based on this model:
The repository provides trained models in ONNX format. If an .hef file for the HAILO-8L is not available, how can I train and compile a .hef file myself?
Thanks in advance for your help!
If you have a model in ONNX format you can use the Hailo Dataflow Compiler to convert it into a HEF file for the Hailo-8L. I would recommend to install the Hailo AI Software Suite docker and walk through the tutorial first. Inside the docker call:
hailo tutorial
I have asked my colleagues to check whether they can give you some pointer with this specific model or provide a HEF file for the Hailo-8L.
Thank you! In the next few days, I will watch the tutorials and try to convert the model.
Hi @brunella.federico,
You can use something like the code below:
######### Parsing #########
model_name = 'ufld_v2_tusimple'
onnx_path = './{}.onnx'.format(model_name)
# The slices and reshapes at the end of the model are currently not supported, so they will
# be performed on the host.
end_node = 'Gemm_51'
runner = ClientRunner(hw_arch='hailo8l')
hn, npz = runner.translate_onnx_model(onnx_path, model_name, end_node_names=[end_node])
hailo_model_har_name = '{}_hailo_model.har'.format(model_name)
######### Optimizing #########
alls_content = [
    'norm_layer1 = normalization([123.675,116.28,103.53],[58.395,57.12,57.365])',
alls_path = './{}.alls'.format(model_name)
open(alls_path,'w').writelines(alls_content)
calib_dataset = np.load('calibset_64_320_800.npy')
runner.load_model_script(alls_path)
quantized_har_path = './{}_quantized.har'.format(model_name)
runner.save_har(quantized_har_path)
######### Compiling #########
hef = runner.compile()
file_name = model_name + '.hef'
with open(file_name, 'wb') as f:
    f.write(hef)
Like instance segmentation models, are there any road segmentation models available for the Hailo-8 AI accelerator? I’m specifically looking for real-time road segmentation solutions optimized for edge devices like the Raspberry Pi 5 with Hailo-8. If there are any pre-trained models or frameworks that support road segmentation on Hailo, I’d love to explore them.
