Kernel Warning (find_vma) during Hailo Driver (v4.23.0) operation on J784S4 EVM
Hello everyone.
We are experiencing a kernel-level warning that prevents our application from running while using the Hailo accelerator on a Texas Instruments J784S4 EVM.
Observed Behavior:
The Hailo driver appears to initialize successfully (as per
dmesg
logs). However, a kernel warning concerning find_vma then occurs during hailo_vdma_buffer_map
-related operations, causing processing to stop.
This issue happens while running an inference with a custom-developed model via the Hailo SDK.
Environment Information:
Hardware: Texas Instruments J784S4 EVM
OS / Kernel Version: Linux 6.12.35-ti-00948-gce4785d01a0b-dirty #1 (ARM64)
HailoRT Version: 4.23.0
Hailo Device: (Hailo-8)
Relevant Log Snippets (from dmesg):
[    7.561291] hailo: Init module. driver version 4.23.0
[    7.600443] hailo 0000:01:00.0: Probing on: 1e60:2864...
[    7.605887] hailo 0000:01:00.0: Probing: Allocate memory for device extension, 9072
[    7.613676] hailo 0000:01:00.0: enabling device (0000 -  0002)
[    7.625027] hailo 0000:01:00.0: Probing: Device enabled
[    7.638223] hailo 0000:01:00.0: Probing: mapped bar 0 - 00000000d51089ae 16384
[    7.651048] hailo 0000:01:00.0: Probing: mapped bar 2 - 0000000004b7ff99 4096
[    7.666931] hailo 0000:01:00.0: Probing: mapped bar 4 - 000000006d82af9d 16384
[    7.683304] hailo 0000:01:00.0: Probing: Setting max_desc_page_size to 4096, (page_size=4096)
[    7.695211] hailo 0000:01:00.0: Probing: Enabled 64 bit dma
[    7.715455] hailo 0000:01:00.0: Probing: Using userspace allocated vdma buffers
[    7.715470] hailo 0000:01:00.0: Disabling ASPM L0s
[    7.715483] hailo 0000:01:00.0: Successfully disabled ASPM L0s
[    7.731108] hailo 0000:01:00.0: Writing file hailo/hailo8_fw.bin
[    7.806322] hailo 0000:01:00.0: File hailo/hailo8_fw.bin written successfully
[    7.814106] hailo 0000:01:00.0: Writing file hailo/hailo8_board_cfg.bin
[    7.814173] hailo 0000:01:00.0: File hailo/hailo8_board_cfg.bin written successfully
[    7.829141] hailo 0000:01:00.0: Writing file hailo/hailo8_fw_cfg.bin
[    7.844133] hailo 0000:01:00.0: File hailo/hailo8_fw_cfg.bin written successfully
[    7.934072] hailo 0000:01:00.0: NNC Firmware loaded successfully
[    7.949196] hailo 0000:01:00.0: FW loaded, took 218 ms
[    7.961554] hailo 0000:01:00.0: Probing: Added board 1e60-2864, /dev/hailo0
[   52.811292] Modules linked in: overlay bluetooth cfg80211 ecdh_generic ecc rfkill snd_usb_audio snd_hwdep uvcvideo snd_usbmidi_lib snd_rawmidi videobuf2_vmalloc uvc onboard_usb_dev rpmsg_ctrl rpmsg_char ti_am335x_adc cdns3 wave5 kfifo_buf cdns_usb_common cdns_pltfrm crct10dif_ce snd_soc_j721e_evm mux_gpio display_connector videobuf2_dma_contig omap_mailbox omap_hwspinlock v4l2_mem2mem phy_can_transceiver videobuf2_v4l2 snd_soc_davinci_mcasp videobuf2_memops ti_k3_r5_remoteproc hailo_pci(O) tidss m_can_platform videobuf2_common cdns_dsi at24 snd_soc_ti_udma m_can cdns_mhdp8546 ti_sn65dsi86 drm_dma_helper snd_soc_pcm3168a_i2c videodev snd_soc_ti_edma snd_soc_pcm3168a ti_am335x_tscadc pvrsrvkm(O) snd_soc_ti_sdma k3_j72xx_bandgap cdns_dphy can_dev drm_display_helper cdns3_ti ti_k3_dsp_remoteproc drm_dp_aux_bus sa2ul drm_kms_helper ti_j721e_ufs ti_k3_common mc rti_wdt cryptodev(O) fuse drm drm_panel_orientation_quirks backlight ipv6
[   52.923645] lr : hailo_vdma_buffer_map+0x144/0x5c0 [hailo_pci]
[   53.009536]  hailo_vdma_buffer_map+0x144/0x5c0 [hailo_pci]
[   53.015011]  hailo_vdma_buffer_map_ioctl+0xd4/0x338 [hailo_pci]
[   53.020918]  hailo_vdma_ioctl+0xc4/0x248 [hailo_pci]
[   53.025871]  hailo_pcie_fops_unlockedioctl+0x1dc/0x600 [hailo_pci]
Questions:
The logs indicate the driver reporting
Using userspace allocated vdma buffers, followed by the find_vma warning. We suspect an issue with DMA mapping of userspace memory.
Is there a known compatibility issue between the current kernel (
6.12.35-ti-00948-gce4785d01a0b-dirty) and Hailo driver (4.23.0)?
Hello. Same find_vma kernel warning here, but on a different config — posting in case it helps narrow down the root cause.
Environment
  • Raspberry Pi 5 (16GB), Hailo-8 (M.2 HAT+, PCIe Gen3 x1)
  • Raspberry Pi OS Bookworm (64-bit), kernel 6.12.87+rpt-rpi-2712
  • HailoRT 4.20.0 / hailo_pci DKMS 4.20.0 (srcversion BD5E76800A08DB052331F58) / firmware 4.20.0
  • Single DKMS driver copy, no in-kernel duplicate. /dev/hailo0 healthy, inference works fine.
Symptom ~135 kernel WARN stack traces per VDevice.configure(): find_vma+0x6c/0x80hailo_vdma_buffer_maphailo_vdma_ioctl, from include/linux/rwsem.h:80. Kernel 6.12.x enforces mmap_read_lock around find_vma(), and the driver calls it unlocked. Harmless to inference, but the log flood slows boot and risks gRPC timeouts (HAILO_RPC_FAILED) on slow I/O.
Note: this is NOT fixed by upgrading. This thread shows it still happens on 4.23.0. And per the 4.23 release notes, 4.23 is Trixie-only — Bookworm users must stay on the earlier release. So upgrading is not an option for us; we need a fix for 4.20.0.
My specific question — correct lock scope for 4.20.0 In /usr/src/hailo_pci-4.20.0/linux/vdma/memory.c, function hailo_vdma_buffer_map, the returned vma is used after find_vma, specifically:
  • is_dmabuf_vma(vma) (dereferences vma->vm_file)
  • create_fd_from_vma(dev, vma) (calls get_file(vma->vm_file))
  • later, fput(vma->vm_file) outside the if (buffer_type != DMABUF) block
The Home Assistant backport (PR #4138, v4.21.0) uses a minimal critical section — lock only around find_vma, unlock immediately. But since vma is dereferenced after find_vma in 4.20.0, an immediate unlock risks use-after-free.
So: should mmap_read_lock be held until after the last vma dereference (through is_dmabuf_vma / create_fd_from_vma), with mmap_read_unlock on every exit path including the goto cleanup branches? Is there an official patch or recommended diff for the 4.20.0 source layout specifically?
I have a full SD image backup and want to apply the correct, deadlock-safe patch and rebuild via DKMS, rather than improvise the lock placement. Thanks!
Hi @ZEQING_YU, @mete_kubilay,
Please see here: Bug report: find_vma() called before mmap_read_lock() issued in /usr/src/hailo_pci-4.23.0/linux/vdma/memory.c
Looks like it’s the same issue we aware of and the upcoming version release will have the fix.
