Kernel module for Ubuntu Only?
Hi folks,
I am guessing my brief check in the git repos, finding “supports linux and windows”, should have been more thorough, before I bought my hailo8.
My goal was to replace my coral device that running fine on my OpenSUSE, providing frigate the hardware it wants.
Although I did have some issues in the beginning, building a new kernel module for the coral device, is a piece of cake these days, whenever I receive a kernel update for Suse.
But it looks like all the hailo kernel stuff, is Ubuntu only? :worried: My attempts at building in the git repos fail completely.
Is there any hope of being able to build an LKM for opensuse? (Currently 15.6)
Br,
Taisto
Thank god for HolgerHees…
But with a fix that’s 7 months old, I am a bit confused why its ignored?
Hey @taisto_qvist,
Welcome to the community!
Great to hear you got it working! If you need any help getting Frigate up and running, feel free to ask.
I’ll pass this issue along to our R&D team so they can look into implementing a proper fix.
I’ve been running frigate with coral for years, so thats easy-piecy :slight_smile: I am a bit confused as to my my inference speed is about three times higher with a much more advanced chip.
My coral had about 6-7 ms, and my hailo is around 15-25+ ms. Running on an i7 nuc, with opensuse 15.6.
#> uname -a
Linux vimes 6.4.0-150600.23.70-default #1 SMP PREEMPT_DYNAMIC Wed Sep 10 10:54:24 UTC 2025 (225af75) x86_64 x86_64 x86_64 GNU/Linux
08:24-Mon_06
root@vimes:~
#> lspci -s 6d:00.0 -vv
6d:00.0 Co-processor: Hailo Technologies Ltd. Hailo-8 AI Processor (rev 01)
        Subsystem: Hailo Technologies Ltd. Hailo-8 AI Processor
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 133
        Region 0: Memory at 404ab04000 (64-bit, prefetchable) [size=16K]
        Region 2: Memory at 404ab08000 (64-bit, prefetchable) [size=4K]
        Region 4: Memory at 404ab00000 (64-bit, prefetchable) [size=16K]
        Capabilities: [80] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 25.000W
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
                        MaxPayload 256 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 8GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR+, OBFF Not Supported
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled
                         AtomicOpsCtl: ReqEn-
                LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
                         EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
        Capabilities: [e0] MSI: Enable+ Count=1/1 Maskable- 64bit+
                Address: 00000000fee00378  Data: 0000
        Capabilities: [f8] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [100 v1] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
        Capabilities: [108 v1] Latency Tolerance Reporting
                Max snoop latency: 3145728ns
                Max no snoop latency: 3145728ns
        Capabilities: [110 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
                L1SubCtl1: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+
                           T_CommonMode=0us LTR1.2_Threshold=90112ns
                L1SubCtl2: T_PwrOn=44us
        Capabilities: [128 v1] Alternative Routing-ID Interpretation (ARI)
                ARICap: MFVC- ACS-, Next Function: 0
                ARICtl: MFVC- ACS-, Function Group: 0
        Capabilities: [200 v2] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr+ BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
                        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
                HeaderLog: 00000000 00000000 00000000 00000000
        Capabilities: [300 v1] #19
        Kernel driver in use: hailo
        Kernel modules: hailo_pci
08:24-Mon_06
Hey @taisto_qvist,
Just wanted to mention - we’re actually getting better performance on Raspberry Pi with just a single PCIe lane, so there might be something we can optimize on your end.
Could you check a few things for me?
  1. Which model are you running?
  2. How many PCIe lanes do you have available, and is it configured for Gen 3?
Also, would you mind running hailortcli run {model.hef} and sharing the FPS output?
Sorry, bit short on time here for fiddling with this stuff, and my hailo seems to have settled at around 13ms now.
Anyway, the NUC is an Intel NUC8i7BEH, and I found this:
Regarding the hailortctl command (since I’m quite new at this), that would require me to fetch hef files from the frigate-container? #N00b
You can connect to the Frigate container and run this command from inside it.
As you can see from your PCIe configuration, you have one slot with 4 lanes and another with 2 lanes. Use one of these slots, set the PCIe generation to Gen 3, and then run the command inside the container.
But I cant find any .HEF files in my frigate container. And running:
root@8eaaae7959b5:/config# hailortcli run hand_landmark_lite.hef
Running streaming inference (hand_landmark_lite.hef):
Transform data: true
Type: auto
Quantized: true
[HailoRT] [error] CHECK failed - Failed to create vdevice. there are not enough free devices. requested: 1, found: 0
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_OUT_OF_PHYSICAL_DEVICES(74)
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_OUT_OF_PHYSICAL_DEVICES(74) - Failed creating vdevice
TQ
Although, after stopping frigate temporarily, and various other fiddling, I managed to get:
#> ./hailort/hailortcli/hailortcli run /root/*hef
Running streaming inference (/root/hand_landmark_lite.hef):
Type: auto
Quantized: true
[HailoRT] [warning] HEF was compiled for Hailo8L device, while the device itself is Hailo8. This will result in lower performance.
Network hand_landmark_lite/hand_landmark_lite: 100% | 1292 | FPS: 256.65 | ETA: 00:00:00
Inference result:
Network group: hand_landmark_lite
Frames count: 1292
FPS: 256.69
Send Rate: 309.11 Mbit/s
Recv Rate: 0.30 Mbit/s
Althought I havent gotten to the part where I check the PCI setting.
Additionally, I have to ask, now that I read and tried to understand the “Set the PCIe generation” to Gen 3….unless I misunderstood something, it cant be anything else. This is Intel NUC is PCIe Gen3, PCIe4 didnt exist when this NUC was built.
Or did I misunderstand something…?
And since i find another .hef:
#> ./repos/hailo/hailort/build/hailort/hailortcli/hailortcli run yolov8m.hef
Running streaming inference (yolov8m.hef):
Type: auto
Quantized: true
Network yolov8m/yolov8m: 100% | 333 | FPS: 66.15 | ETA: 00:00:00
Inference result:
Network group: yolov8m
Frames count: 333
FPS: 66.16
Send Rate: 650.37 Mbit/s
Recv Rate: 646.31 Mbit/s
Did my results provide any useful info?
Hey @taisto_qvist,
Thanks for sharing all that info!
So if I’m understanding correctly, you’re able to run one model but hitting issues with the other. The first one didn’t run initially because something else was already using the device (probably the main Frigate app), but then it worked after that.
I’m curious about the model with hand_landmark_lite - what kind of post-processing does it have configured? That can sometimes impact inference performance.
can you try running hailortcli parse-hef on the model you’re trying to use and let me know what that shows?
Also, I noticed that model was compiled for Hailo-8L, but you’re running Hailo-8. I’d definitely recommend recompiling it specifically for Hailo-8 - you should see much better performance, possibly up to 2x faster.
Summary:
Your Hailo installation looks good overall. The model does run, and that first issue was just a blocking conflict that resolved itself. The main thing is you’re using a Hailo-8L compiled model on Hailo-8 hardware - recompiling for Hailo-8 should give you significantly better performance.
Important: Make sure you’re using the correct HailoRT branch for Hailo-8. For Hailo-8, Hailo-8R, and Hailo-8L, you need to use the hailo8 branch (version 4.23 or 4.21), not master.
Note Make sure the post-process is ran correctly in frigate , i can do this when you provide me the details of the model!
First off, there is a slight assumption that I know what I am doing here, that’s a bit off :slight_smile:
I have no real knowledge of how these tools and software work, I am just able to fiddle them together, run commands that you ask of me, but thats about it.
Did you notice that I found another model that was not built for the hailo8l? The yolov8m?
#> ./repos/hailo/hailort/build/hailort/hailortcli/hailortcli parse-hef yolov8m.hef
Network group name: yolov8m, Multi Context - Number of contexts: 3
Network name: yolov8m/yolov8m
VStream infos:
Input yolov8m/input_layer1 UINT8, NHWC(640x640x3)
Output yolov8m/yolov8_nms_postprocess FLOAT32, HAILO NMS BY CLASS(number of classes: 80, maximum bounding boxes per class: 100, maximum frame size: 160320)
Operation:
Op YOLOV8
Score threshold: 0.200
IoU threshold: 0.70
Classes: 80
Max bboxes per class: 100
Image height: 640
Image width: 640
I also tried with this one:
https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v2.17.0/hailo8/yolov8s.hef
#> ./repos/hailo/hailort/build/hailort/hailortcli/hailortcli run yolov8s.hef
Running streaming inference (yolov8s.hef):
Type: auto
Quantized: true
Network yolov8s/yolov8s: 100% | 2454 | FPS: 490.19 | ETA: 00:00:00
Inference result:
Network group: yolov8s
Frames count: 2454
FPS: 490.21
Send Rate: 4818.94 Mbit/s
Recv Rate: 4788.82 Mbit/s
Which parses as:
#> ./repos/hailo/hailort/build/hailort/hailortcli/hailortcli parse-hef yolov8s.hef
Network group name: yolov8s, Single Context
Network name: yolov8s/yolov8s
VStream infos:
Input yolov8s/input_layer1 UINT8, NHWC(640x640x3)
Output yolov8s/yolov8_nms_postprocess FLOAT32, HAILO NMS BY CLASS(number of classes: 80, maximum bounding boxes per class: 100, maximum frame size: 160320)
Operation:
Op YOLOV8
IoU threshold: 0.70
Classes: 80
Image height: 640
Image width: 640
When it comes to my actual model run in frigate, I dont know how to extract it! Since if I enter the frigate container there are no hef files anywhere.
I am using frigate+, and just supply a model id a la “plus://”, and dont now how the model is acquired.
Also note that frigate container builds will match its hailo-drivers to what is supported in the HAOS, so currently I am stuck at v.4.21.0.
I did just notice though, that I was using the 640x640 model, and when I changed to the 320x320, inference times dropped to ~14ms. But if I should be happy with that I have no clue.
What I feel is MOST IMPORTANT though, is the fact that no-one seems to care about the build fix in #PR22, which is such a simple fix I cant understand why its not merged.
Without it, I cant build from more up2date code, from the real repo.
Br,
Taisto
Hey @taisto_qvist,
The PR you provided has been passed to R&D to look at integrating it. For now, I’d recommend forking the hailort repository, adding this change yourself, and compiling from source. This will get your issue fixed on your end while we work on the integration!
I’ve got most of what I need to help, but a few quick things: You’ve got a Hailo8, not Hailo8L, so make sure you’re running the Hailo8 configuration for best performance. You can control the model through Frigate’s config—check out this thread for examples: Hailo official integration with Frigate - #19 by Genelec
Your detector config should look something like this:
detectors:
  hailo8l:
    type: hailo8l
    device: PCIe
model:
  path: https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v2.17.0/hailo8/yolov8s.hef
If you haven’t changed the model, it’s probably running SSDMobileNet v1 or YOLOv6n by default. Also, we’re upgrading to version 4.23 across HOAS and Frigate—we’ve got a ticket for HOAS and a PR coming soon for Frigate.
If changing the model doesn’t help, can you jump into the Frigate container and run hailortcli fw-control identify to verify everything’s working correctly? And if you could share your hailort.log file, that would help too—sometimes issues show up in the logs even when detection seems to be running fine.
Of course I am building from the branch that has the fix, otherwise this would not work at all, but since the fix is a one-liner, its strange that it should take longer than 5 minutes to review and merge, considering it only enables compilation on a higher linux kernel version, and doesnt contain any actual code/logic changes.
The output from the command you wanted is:
Executing on device: 0000:6d:00.0
Identifying board
Control Protocol Version: 2
Firmware Version: 4.21.1 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8
Serial Number: HLLWM2B233704198
Part Number: HM218B1C2FAE
Product Name: HAILO-8 AI ACC M.2 M KEY MODULE EXT TEMP
But I cant find any hailort.log anywhere in my frigate container. Additonally, as I said before, I am using the frigate-plus ( Frigate+ | Frigate ) version which means that I am NOT manually supplying the path to a module.
Instead my frigate config just refers to a model-url a la “plus:// ”, and then the rest is handled by frigate.
I have not been able to find any .hef files or similar in a running container.
Is my info still not useful?
And I can still not fathom why the PR fixes that have been made available to solve compilation of newer kernels, have not been accepted.
Why are single line, obvious bugfixes, not merged??
