Has the software development for the Hailo H10/ RPI5 AI Hat +2 stalled? Noticed Hailo was consistently doing quarterly updates but nothing was posted for July. Been waiting patiently for bigger generative AI models.
The development for Hailo-10 is still active. The next update is currently expected at the end of this month.
Ok, thank you for the update, I appreciate and am looking forward to it.
Thereās actually some activation on the hailo repos at github for 5.4.0. E.g. Release v5.4.0 Ā· hailo-ai/hailort-drivers Ā· GitHub but there are still some other repos missing and the deb-packages in the dev zoe are not yet updated.
@Klaus_Koschinsky any updates here? As weāre already in September.
The Hailo AI Software Suite 2026-08 for Hailo-10, along with all individual packages for version 5.4.0, has been released and is now available for download from the Developer Zone.
Thanks @Klaus_Koschinsky - however when running this command on the RPI it still says āCandidate: 5.1.1ā
apt-cache policy hailo-h10-all h10-hailort h10-hailort-pcie-driver
When will that be updated to feature the latest version?
As a consumer user, I can only use version Hailo v5.1.1 via Raspberry Pi Update.
@Stefan_Schulte : You can download the packages from https://hailo.ai/developer-zone/software-downloads/?product=ai_accelerators&device=hailo_10h after registration (which can be done by everyone). Make sure you have the correct packages for your architecture and remove the packages which are installed from the official repositories because they conflict.
The git-repositories donāt have the new code yet (at least not the model_zoo_genai) and the accelerator-integration-tool seems to be still 5.3.0
We are working on streamlining the update process for installations via APT. As the packages involved are maintained and distributed across multiple parties, there are a few things we need to coordinate regarding responsibilities and timing as the process evolves, particularly in light of the transition to Microchip.
In the meantime, as Matthias pointed out, you can replace the APT packages with the latest versions available from the Developer Zone.
Thank you for pointing this out. Most packages for Hailo-10 have been updated to 5.4.0. I will check with my colleagues.
so update 5.4.0 install, pci driver, hailo RT and zoo, However:
I get the following error now when I issue
curl --silent http://localhost:8000/api/pull -H āContent-Type: application/jsonā -d ā{ āmodelā: āqwen3:1.7bā, āstreamā : true }ā
{āerrorā:āno complete blob pair (HEF + .sha256 companion) for Qwen3-1.7B-Instruct.hef at v5.4.0 or fallback v5.3.0ā}
and on the Hailo-ollama CMD it gives the error
W |2026-09-13 20:02:24 1789322544783472| BlobResourceProvider:unexpected HTTP 403 probing /v5.4.0/blob/Qwen3-1.7B-Instruct.hef, treating as absent
W |2026-09-13 20:02:24 1789322544887565| BlobResourceProvider:unexpected HTTP 403 probing /v5.3.0/blob/Qwen3-1.7B-Instruct.hef, treating as absent
Ok, as I see that this fw is still in validation and there is still no documentation available for 5.4.0 . So i will need to wait for the apt update.
But to be honest I am a bit frustrated, that I bought a Hailo 10H Ai Hat 2+ at Launch this year but until today there is now new FW (then the initial 5.1.1) nor new GenAi models released what was advertised with this product..
I feel your frustration, a Jetson Nano would cost approx. the same and be up and running out of the box. I donāt know what is going on at Hailo but it seems there are no real developers or support assigned to the RPI channel and it is treated like a sidequest. There might also be other circumstances we are not aware of but at this point I have to write this off and warn other potential users and adopters. The Raspi foundation also has been no help with an outdated APT deployment not even working on the latest kernel. Itās like buying a hammer and it has to be assembled first before you can use it to knock in nails
Hello everyone. I am experiencing the exact same issue reported here. After updating to HailoRT 5.4.0, I am unable to pull any GenAI models (e.g., qwen3:1.7b) due to the no complete blob pair (HEF + .sha256 companion) error and the HTTP 403 from the blob server. Could you please confirm if this issue has been resolved? If so, could you share the steps to fix it? Thank you.
Hi @Leandro_Cutuli,
I couldnāt reproduce the issue on my side with HailoRT 5.4.0 and GenAI Model Zoo 5.4.0.
Could you try running these and share the output?
hailortcli --version
dpkg -l | grep -E āhailortā
type -a hailo-ollama
which hailo-ollama
readelf -d ā$(which hailo-ollama)ā | grep libhailort
Iām wondering if there might be an older hailo-ollama installation or some mixed/stale packages being picked up.
Thank you very much for the response.
I attach the response of the indicated commands:
HailoRT-CLI version 5.4.0
bash: hailo-gen-ai: command not found
hailo-ollama is /usr/local/bin/hailo-ollama
hailo-ollama is /usr/bin/hailo-ollama
hailo-ollama is /bin/hailo-ollama
0x0000000000000001 (NEEDED) Shared library: [libhailort.so.5.4.0]
Thanks! Could you try starting Hailo-Ollama directly from the packaged binary?
Then, from another terminal, try pulling the model again:
curl --silent ``http://localhost:8000/api/pull``
-d ā{āmodelā:āqwen3:1.7bā,āstreamā:true}ā
Your system is picking /usr/local/bin/hailo-ollama first, so this will tell us if that older/manual installation is causing the issue.
Thanks for the suggestion. I tried running /usr/bin/hailo-ollama directly, but I am still running into an error during the pull process.
When I run the curl command in the second terminal, it fails with this output:
Descargando qwen3:1.7bā¦
Meanwhile, the terminal running hailo-ollama shows the following log:
W |2026-10-08 11:15:03 1791468903563987| BlobResourceProvider:unexpected HTTP 403 probing /v5.3.0/blob/Qwen3-1.7B-Instruct.hef
It looks like the system is hitting an HTTP 403 Forbidden error when trying to fetch the fallback HEF blob from the server, causing the pull to fail.
@Leandro_Cutuli Sorry for the delayed response. I tried reproducing the issue in a few different ways on my side but wasnāt able to. It may be specific to your environment or network.
I also saw your other topic about requests to dev-public.hailo.ai being blocked by Cloudflare. I wonder if the two issues are related. Have you had a chance to try from a different network?
