Is there a documented flow for compiling a custom/fine-tuned LLM to the Hailo-10H LLM pipeline?
Hi all!
I’m interested in running a custom or fine-tuned LLM on the Hailo-10H (AI HAT+ 2), beyond the models currently shipped in the hailo-rpi5-examples LLM pipeline.
Specifically, is there a documented way to compile a fine-tune of one of the existing architectures (e.g. Llama 3.2 1B) to .hef, or is the LLM pipeline currently limited to the three pre-converted models? Any guidance would be appreciated. Thanks!
At the moment, it is not possible to compile your own LLM for Hailo. However, we do support LoRA, which allows you to add domain-specific knowledge to a supported model.
The Hailo AI Software Suite Docker includes a LoRA tutorial. You can start the Jupyter Notebook server, which contains notebooks covering each step of the model conversion workflow, including a dedicated LoRA notebook, by running:
hailo tutorial
