Is Profiling Possible with MPS? (HRTT / NPU Utilization Not Available)
Hello Hailo Support Team,
I’ve previously been able to profile successfully when using the HailoRT scheduler with a Round Robin setup — in that case, both the HRTT report opens normally and NPU utilization can be measured/read correctly.
However, with MPS, I’m seeing different behavior: the HRTT profiling file is still generated, but it never opens (the report won’t load / the viewer fails every time). At the same time, NPU utilization is not available while MPS inference is running.
Is this a known limitation (profiling/monitoring not fully supported under MPS), or is there a separate workflow/tool to (1) view/convert the HRTT output and (2) monitor NPU utilization when using MPS?
Thanks in advance for any guidance!
