I am considering using the Hailo-8 M.2 for inference of text and speech in my language.
After converting them to English, it would communicate with a larger model. Would the Hailo-8 M.2 be suitable for this purpose?
Best regards,
A.H.
Best regards,
A.H.
Hey @Aleksandr_Hristov,
If your goal is to run translation or speech-to-text on the Hailo-8 and then send that data to a larger model elsewhere (like a server or API), then yes, this will work perfectly! We’ll soon have the Whisper model available for Hailo-8, which will handle the speech recognition part nicely.
However, if you’re hoping to run the larger model directly on the Hailo-8, I’m afraid that’s not possible. For those more demanding NLP tasks, we’re bringing the Hailo-10H to market specifically designed for handling larger language models.
Let me know if you have any other questions !
Thank you for your response. I’m considering two options for using the Hailo-8 with the Raspberry Pi 5:
I’m still in the research phase. I’ve had some bad experiences with IoT boards in the past, so I’m being cautious with my purchases.
Has anyone here had experience with either of these devices?
Best regards,
can’t wait for whisper to come out and test it. I have a Rpi5 16GB with ssd and hailo l8 chip. Is there more possible with piper and openwakeword. I can’t find the Hailo H10 m2 anywhere to buy.
I bought this myself and it works with Hailo L8 chip and SSDhttps://vi.aliexpress.com/item/1005007472159584.html?spm=a2g0o.order_list.order_list_main.22.31481802lD9Ye8&gatewayAdapt=glo2vnm
For the moment my project is frozen.
I’m still trying to clear my concept of what and how I want it to work ![]()
I’ll keep in mind if I start with 1 Halio module, but I’m considering a Geekworm 4 M.2 slot module. I don’t know if Halio support multitasking in their models.
Hey @Coen_Dijkshoorn,
Hailo10 isn’t available yet—we’ll post an update as soon as it’s officially released!
Yeah, we do support multitasking—either with the scheduler (which is recommended), or by combining models (which is less ideal, but possible).
You can also run across multiple chips, you just need to handle resource management and model compilation properly.
