Input and output issues of the CLIP ViT-B/16 image encoder
I encountered an issue when using the clip_vit_b_16_image_encoder public model from hailo_model_zoo (version 2.17). The model library link is: hailo_model_zoo/docs/public_models/HAILO8/HAILO8_zero_shot_classification.rst at update-to-version-2.17 · hailo-ai/hailo_model_zoo · GitHub .
I fed the same preprocessed data into both the ONNX model and HEF model included in the library, but the output vectors of the two models are inconsistent. Could anyone help with this? I would like to know how to configure or adjust the operations to make the output vector of the HEF model consistent with that of the ONNX model.
The following is the running code
import onnxruntime as ort
from PIL import Image
from torchvision import transforms
from torchvision.transforms import functional as TF
from hailo_platform import HEF, VDevice, InputVStreamParams, OutputVStreamParams, FormatType, HailoStreamInterface, InferVStreams, ConfigureParams,HailoSchedulingAlgorithm
normalize = transforms.Normalize(mean=[0.48145466, 0.4578275, 0.40821073],
                                 std=[0.26862954, 0.26130258, 0.27577711])
def onnx_infer(onnx_path,img_array):
    # 创建ONNX Runtime会话
    session = ort.InferenceSession(onnx_path, providers=["CPUExecutionProvider"])
    input_name = session.get_inputs()[0].name
    output_name = session.get_outputs()[0].name
    onnx_output = session.run([output_name], {input_name: img_array})[0]
    return onnx_output.squeeze()
def hef_infer(hef_path,img_array):
    first_hef2 = HEF(hef_path)
    hefs = [first_hef2]
    # Creating the VDevice target with scheduler enabled
    params.multi_process_service = True
    params.group_id = "SHARED"
    target = VDevice(params)
    configure_params0 = ConfigureParams.create_from_hef(hefs[0], interface=HailoStreamInterface.PCIe)
    model_name0 = hefs[0].get_network_group_names()[0]
    batch_size = 1
    configure_params0[model_name0].batch_size = batch_size
    network_groups0 = target.configure(hefs[0], configure_params0)
    network_group0 = network_groups0[0]
    input_vstreams_params0 = InputVStreamParams.make(network_group0, quantized=False,format_type=FormatType.FLOAT32)
    output_vstreams_params0 = OutputVStreamParams.make(network_group0, quantized=True,format_type=FormatType.FLOAT32)
    input_vstream_info0 = hefs[0].get_input_vstream_infos()[0]
    output_vstream_info0 = hefs[0].get_output_vstream_infos()[0]
    input = input_vstream_info0.name
    input_dict = {input: img_array}
    with InferVStreams(network_group0, input_vstreams_params0, output_vstreams_params0, tf_nms_format = True) as infer_pipeline0:
        output_data = infer_pipeline0.infer(input_dict)
        tt = output_data[output_vstream_info0.name].squeeze()
        return tt
def read_img(img_path):
    img = Image.open(img_path).convert('RGB')
    img = TF.resize(img, 224, transforms.InterpolationMode.LANCZOS)
    img = TF.center_crop(img, (224,224))
    img = TF.to_tensor(img).to('cpu')
    img = normalize(img)
    img_np = img.numpy()
    img_array = np.expand_dims(img_np, axis=0)
    return img_array
img_array=read_img('./mountain-477832_1280.jpg')
onnx=onnx_infer('./clip_vit_b_16.onnx',img_array)
hef=hef_infer('./clip_vit_b_16_image_encoder.hef',img_array)
cos_sim = np.dot(onnx, hef) / (
    np.linalg.norm(onnx) * np.linalg.norm(hef)
l2_dist = np.linalg.norm(onnx - hef)
print(f"cos_sim:{cos_sim},l2_dist:{l2_dist}")
The following is the running result
