The issue im facing and im using degirum sdk for model inferencing
This is the libraries i have installed on raspbeery pi 5 and im using hailo8l
This is the kernal version
Hi @SAN
Can you share the output of typing degirum sys-info
in command line?
Hi @SAN
From this it appears that Hailo device is not recognized by the degirum pysdk. @Stephan_Sokolov can you help @SAN figure out if HailoRT is properly installed?
okkay iits not been detected got it
but based on the dependencies list the hailort it properly installed, right?
Hi @SAN
Can you type this and let us know the output?
i did already but its not showing any error or any hailo info just blank
kinda weird thou
Hi @SAN
So, it looks like hailort itself is not properly installed. It could either be the driver or the runtime. Can you try lspci
erm i dont think so because this is runnig in a docker environment and im able to run this in raspi os gui vertion and when im test this in lite vertion raspi vertion this error prompting
and this is the lspci command output
@SAN
Since hailortcli
itself is not working (i.e. it cannot find vdevice), I believe this is not our pysdk issue. Sorry, I could not be of help.
yep waiting for hailo developer on supports
