## Problem Description and Resolution Summary
A detailed summary of the issue encountered with the face attribute analysis pipeline and the steps taken to resolve it.
The Problem
The primary issue was a fatal error in the GStreamer pipeline during the face attribute analysis stage, immediately after successful face detection.
- Error Message:
[HailoRT] [error] No tensor with name face_attr_resnet_v1_18_rgbx/fc3 - Symptoms:
- Face detection worked correctly.
- Face attribute analysis (age/gender estimation) failed to run.
- The GStreamer pipeline would terminate prematurely.
Root Cause Analysis
The investigation revealed a clear mismatch between the AI model and the post-processing library.
- Tensor Name Mismatch
- Actual Model Output:
face_attr_resnet_v1_18/fc3 - TAPPAS Library Expectation:
face_attr_resnet_v1_18_rgbx/fc3 - Discrepancy: The library was hardcoded to look for a tensor name with an unnecessary
_rgbxsuffix.
- Locating the Faulty Code The incorrect tensor name was found hardcoded in the TAPPAS C++ source code.
- File:
face_attributes.cpp:124 - Incorrect Code:
C++face_attributes_postprocess(roi, "face_attr_resnet_v1_18_rgbx/fc3"); - Correct Code:
C++face_attributes_postprocess(roi, "face_attr_resnet_v1_18/fc3");
