How to use your smart phone as an RTSP camera?
Always wanted to stream some video from an rtsp camera but never had one?!?
Turn your smartphone into an rtsp camera, watch the how to clip here: https://www.youtube.com/watch?v=PDxxCuUa_iE
I downloaded the ‘RTSP Camera Server Pro’ app on my android and it streamed the video with zero effort to vlc on my laptop.
Advanced users are welcome to combine the rtsp camera as a source into Hailo’s face recognition Tappas app.
gst-launch-1.0 rtspsrc latency=0 location=rtsp://192.168.68.104:1935 name=source_0 ! \
rtph264depay ! h264parse ! avdec_h264 ! \
queue name=hailo_pre_id_0 leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailofilter name=set_id_0 so-path=apps/h8/gstreamer/libs/post_processes/libstream_id_tool.so function-name=set_stream_id config-path=test_0 qos=false ! \
queue name=hailo_pre_convert_0 leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
videoconvert n-threads=2 qos=false ! \
queue name=pre_detector_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
tee name=t hailomuxer name=hmux t. ! \
queue name=detector_bypass_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hmux. t. ! videoscale name=face_videoscale method=0 n-threads=2 add-borders=false qos=false ! \
video/x-raw, pixel-aspect-ratio=1/1 ! \
queue name=pre_face_detector_infer_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailonet hef-path=apps/h8/gstreamer/general/face_recognition/resources/scrfd_10g.hef scheduling-algorithm=1 vdevice-key=1 ! \
queue name=detector_post_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailofilter so-path=apps/h8/gstreamer/libs/post_processes//libscrfd_post.so \
name=face_detection_hailofilter qos=false config-path=apps/h8/gstreamer/general/face_recognition/resources/configs/scrfd.json function_name=scrfd_10g ! \
queue leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hmux. hmux. ! queue name=pre_tracker_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailotracker name=hailo_face_tracker class-id=-1 kalman-dist-thr=0.7 iou-thr=0.8 init-iou-thr=0.9 keep-new-frames=2 keep-tracked-frames=6 keep-lost-frames=8 keep-past-metadata=true qos=false ! \
queue name=hailo_post_tracker_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailocropper so-path=apps/h8/gstreamer/libs/post_processes//cropping_algorithms/libvms_croppers.so function-name=face_recognition internal-offset=true name=cropper2 hailoaggregator name=agg2 cropper2. ! \
queue name=bypess2_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
agg2. cropper2. ! queue name=pre_face_align_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailofilter so-path=apps/h8/gstreamer/libs/apps/vms//libvms_face_align.so name=face_align_hailofilter use-gst-buffer=true qos=false ! \
queue name=detector_pos_face_align_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailonet hef-path=apps/h8/gstreamer/general/face_recognition/resources/arcface_mobilefacenet_v1.hef scheduling-algorithm=1 vdevice-key=1 ! \
queue name=recognition_post_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailofilter function-name=arcface_rgb so-path=apps/h8/gstreamer/libs/post_processes//libface_recognition_post.so name=face_recognition_hailofilter qos=false ! \
queue name=recognition_pre_agg_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
agg2. agg2. ! queue name=hailo_pre_gallery_q leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailogallery gallery-file-path=apps/h8/gstreamer/general/face_recognition/resources/gallery/face_recognition_local_gallery_rgba.json load-local-gallery=true similarity-thr=.4 gallery-queue-size=20 class-id=-1 ! \
queue name=hailo_pre_draw2 leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailooverlay name=hailo_overlay qos=false show-confidence=false local-gallery=true line-thickness=5 font-thickness=2 landmark-point-radius=8 ! \
queue name=hailo_post_draw leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
videoconvert n-threads=4 qos=false name=display_videoconvert qos=false ! \
queue name=hailo_display_q_0 leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
fpsdisplaysink video-sink=xvimagesink name=hailo_display sync=false text-overlay=false
