How to use gpu during quatization process using hailo_sdk_client
Currently i am optimizing the model on linux OS that came with the hailo chip and camera. how do i use a gpu. i do have a 4090 on my system but i dont know whether i can quantize the model locally without the hailo architecture. Other than that, how to use any other gpus (a100, h100s etc). Kindly share some piece of documentation or code that provids some guidance into using gpus
Ive attached my code for reference.
import json
import onnx
from pprint import pprint
import tensorflow as tf
from IPython.display import SVG
from matplotlib import patches
from matplotlib import pyplot as plt
from PIL import Image
from tensorflow.python.eager.context import eager_mode
onnx_model_name = “yolo11m_EXP3”
onnx_path = “/local/shared_with_docker/models/yolo11m_EXP3.onnx”
chosen_hw_arch = “hailo8” # Specify the target hardware architecture
“”“yolo11m”“”
end_node_names = [
“/model.23/cv2.0/cv2.0.2/Conv”, #41 reg_layer
“/model.23/cv3.0/cv3.0.2/Conv”, #42 cls_layer
“/model.23/cv2.1/cv2.1.2/Conv”, #52 reg_layer
“/model.23/cv3.1/cv3.1.2/Conv”, #53 cls_layer
“/model.23/cv2.2/cv2.2.2/Conv”, #62 reg_layer
“/model.23/cv3.2/cv3.2.2/Conv”, #63 cls_layer
model = onnx.load(onnx_path)
onnx_path,
onnx_model_name,
end_node_names=end_node_names,
net_input_shapes={“images”: [1, 3, 640, 640]},
# hailo_model_har_name = f"/local/shared_with_docker/models/{onnx_model_name}_hailo_model.har"
# hailo_model_har_name = f"/local/exploration/{onnx_model_name}_hailo_model.har"
# runner.save_har(hailo_model_har_name)
hailo_model_har_name = f"/local/shared_with_docker/{onnx_model_name}_hailo_model.har"
try:
# Access the HailoNet as an OrderedDict
hn_dict = runner.get_hn() # Or use runner._hn if get_hn() is unavailable
print(“Inspecting layers from HailoNet (OrderedDict):”)
for key, value in hn_dict.items():
    print(f"Key: {key}")
    pprint(value)
    print("\n" + "="*80 + "\n") # Add a separator between layers for clarity
except Exception as e:
    print(f"Error while inspecting hn_dict: {e}")
# nms_layer_config = {
# “nms_scores_th”: 0.2,
# “nms_iou_th”: 0.7,
# “image_dims”: [
# 640,
# 640
# “max_proposals_per_class”: 100,
# “classes”: 1,
# “regression_length”: 16,
# “background_removal”: False,
# “background_removal_index”: 0,
# “bbox_decoders”: [
# “name”: “bbox_decoder71”,
# “stride”: 8,
# “reg_layer”: “conv71”,
# “cls_layer”: “conv74”
# “name”: “bbox_decoder87”,
# “stride”: 16,
# “reg_layer”: “conv87”,
# “cls_layer”: “conv90”
# “name”: “bbox_decoder102”,
# “stride”: 32,
# “reg_layer”: “conv102”,
# “cls_layer”: “conv105”
# output_dir = “/local/exploration/nms_config”
# os.makedirs(output_dir, exist_ok=True)
# output_path = os.path.join(output_dir, “nms_layer_config_yolo11m.json”)
# with open(output_path, “w”) as json_file:
# json.dump(nms_layer_config, json_file, indent=4)
# print(f"NMS layer configuration saved to {output_path}")
# original dataset
path = "/local/shared_with_docker/calliberation_data_v3_npy/processed_calibration_data.npy"
N, H, W, C = 1233, 640, 640, 3
calib_data = np.memmap(path, dtype=np.float32, mode=‘r’, shape=(N, H, W, C))
# calib_data = np.array(path, dtype=np.float32)
print(calib_data.shape, calib_data.dtype, type(calib_data))
## SDK_FP_OPTIMIZED
# # conf for yolo8n:
# alls = "
# normalization1 = normalization([0.0, 0.0, 0.0], [255.0, 255.0, 255.0])
# change_output_activation(conv74, sigmoid)
# change_output_activation(conv90, sigmoid)
# change_output_activation(conv105, sigmoid)
# nms_postprocess(“/local/shared_with_docker/nms_config/nms_layer_config_yolo11m.json”, meta_arch=yolov8, engine=cpu)
# allocator_param(width_splitter_defuse=disabled)
# inc in alls:
# post_quantization_optimization(finetune, policy=enabled, loss_factors=[0.125, 2, 0.25, 0.125, 2, 0.25, 0.125, 2, 0.25, 1, 1, 1], dataset_size=4000, epochs=8, learning_rate=1e-5, loss_layer_names=[conv36, conv37, conv38, conv47, conv48, conv49, conv57, conv58, conv59, conv33, conv43, conv54], loss_types=[l2, l2, l2, l2, l2, l2, l2, l2, l2, l2rel, l2rel, l2rel])
# performance_param(compiler_optimization_level=max)
# allocator_param(enable_post_split_average_buffers=disabled)
# conf for yolo11m:
alls = "
model_optimization_config(calibration, batch_size=1)
# performance_param(compiler_optimization_level=max) - To achieve optimal performance, set the compiler_optimization_level to “max”
# post_quantization_optimization(finetune, policy=enabled, learning_rate=0.00001)
# resources_param(max_apu_utilization=0.8, max_compute_16bit_utilization=0.8, max_compute_utilization=0.8, max_control_utilization=0.8, max_input_aligner_utilization=0.8, max_memory_utilization=0.8, max_utilization=0.0)
# model_optimization_flavor(optimization_level=0)
runner.load_model_script(alls)
runner.optimize_full_precision()
## SDK_QUANTIZED
runner.optimize(calib_data)
# Save the optimized model to a new Quantized HAR file
quantized_model_har_path = f"/local/shared_with_docker/{onnx_model_name}_quantized_model.har"
print(f"Quantized HAR file saved to: {quantized_model_har_path}")
## COMPILATION
runner = ClientRunner(har=quantized_model_har_path)
print("[info] ClientRunner initialized successfully.")
hef = runner.compile()
file_name = f"/local/shared_with_docker/{onnx_model_name}.hef"
with open(file_name, "wb") as f:
    f.write(hef)
Please review the Hailo AI Software Suite User Guide section Suite Installation. You can download it from the Developer Zone. There is also a link to the installation guide right next to the individual software downloads in the Developer Zone.
I recommend using the Hailo AI Software Suite Docker.
When the installation is done correctly, the GPU will be used automatically by the Dataflow Compiler for tasks that can make use of a GPU.
I use this GPU myself and its a good choice.
The same guide above gives examples of supported GPUs.
I was able to use the gpu quring quantization but the bulk of time (8 hours) was taken during compilation, and for some reason the gpu is not being used during compiling.
is there any otehr way to spped up the compiling time? is gpu supposed to be used during this?
regards
Are you using performance mode for the compiler? This method of compilation will require significantly longer time to complete. See Hailo Dataflow Compiler User Guide - Performance Param.
