Hi everyone,
I am pretty new to hailo, so far i learnt to use a .hef model on a rpi 5 with hailo 10H. Now I want to convert my own model from onnx to hef. I have read tutos and documentations (DFC doc) and I still have trouble. On a x86 machine with DFC i manage to parse, optimize and compile an hef model from my custom model (specifying the end_nodes), but I would like to know if it were possible to include the post processing into the hef model ?
I’ve read about the nms_post_processing in the .alls and the .json it needs but I don’t understand how to make it work and how it works.
Does anyone can enlight me ?
Thank you in advance.
Hi, yes - you can and should include the NMS post-processing in your HEF. It’s the recommended approach. When you parse your ONNX model, you cut the graph before the NMS/decode layers using end_node_names. Then you tell the DFC to re-attach an optimized NMS implementation via the nms_postprocess command in your .alls model script. This gets baked into the HEF so HailoRT handles it automatically at runtime.
For example, see the official YOLOv8s .alls script in the Hailo Model Zoo. Also see this relevant community thread: Not Sure If I Properly Converted Yolo 8 Model
Thank you for your answer,
I still have some questions about the example you gave me.
In yolov8s.alls, the change_output_activation(convXX, sigmoid) add a sigmoid after convXX ?
In the .json and .alls they use convXX but in my onnx the nodes are named differently, does it exist a way to see the end nodes names in the har file ?
This question is more generalist but is it possible to convert custom Neural Network ?
Thank you.
You can view har files in Netron.
Yes, please check out the tutorials in the Hailo AI Software Suite Docker. Inside the Docker run the following command to start a Jupyter Notebook server with notebooks for each step of the workflow.
hailo tutorial
Thank you a lot. That clarify a lot of things for me.
Not sure if this is a good place or not but, does anyone have a script for converting huggingface “Gemma 4”. I’ve managed a script for “Stable Diffusion” models. Has anyone developed scripts &/or processes for any of the conversions, followed by optimization and .hef?
TIA
-M
