When training, I am using the normalization like this:
self.normalize = transforms.Normalize(mean=[0.485, 0.456, 0.406], std=[0.229, 0.224, 0.225])
But the documentation says that it expects the input to be in range [0-255] and uses the normalization like this to do the on-device normalization:
normalization1 = normalization([123.675, 116.28, 103.53], [58.395, 57.12, 57.
,→375])\n”,
I also got warning when trying to optimise on images scaled on range [0-1]
[warning] The expected calibration set should be [0, 255] when using an in-net normalization layer, but the range received is [(0.0, 1.0), (0.0, 1.0), (0.0, 1.0)].
[info] The calibration set seems to not be normalized, because the values range is [(-1.0, 1.0), (-1.0, 1.0)].
Since the neural core works in 8-bit (between 0 to 255), a quantization will occur on the CPU of the runtime platform.
Add a normalization layer to the model to offload the normalization to the neural core.
Refer to the user guide Hailo Dataflow Compiler user guide / Model Optimization / Optimization Related Model Script Commands / model_modification_commands / normalization for details.
My question is, since my model is trained on images in the range [0-1], should I use my original normalization, follow the documentation, or apply normalization externally?
