Note that it requires Hailo-RT multi-process service to be running in the background. If you have installed Hailo-RT on a Ubuntu distribution, the debian installation package would have asked you if you wanted to install with Hailo-RT service. If you are installing using Yocto, please refer to: GStreamer parallel inference - #3 by lieberwirth
If you don’t want to use Hailo-RT multi-process service, there is also a way to run multiple gstreamer pipelines in parallel: you just need to add device-count=1 vdevice-key=1 to the options of hailonet and run all the gstreamer pipelines under the same gst-launch-1.0 command. Note that since these pipelines are independent from each other, there is no delimiter ‘!’ between them.
Hi, i try to run two gstreamer pipelines in parallel, i followed this article by adding **multi-process-service=true device-count=1 vdevice-key=1 parameters to hailonet element and i’m getting this error: gst_parse_error: no property “vdevice-key” in element “hailonet”. could you please suggest solution ?
Hi, in the latest version of hailonet vdevice-key is replaced with vdevice-group-id . You can run the command gst-inspect-1.0 hailonet to see the meaning of each field. The previous version of hailonet is still available and is renamed to synchailonet .
@user313@Klaus_Koschinsky Would it be not-recommended to run 8 streams at 3fps with Yolo v8, each stream with its own gstreamer process/pipeline? The only con I can think of would be higher memory usage. My concern would be if the scheduler could keep up with this setup.
@yuri If your host CPU can handle the pre- and post-processing of the 8 video streams you should be fine. I do not expect issues with the HailoRT scheduler.
