Could not load lib /usr/local/hailo/resources/so/libyolo_hailortpp_postprocess.so: cannot open shared object file: No such file or directory
Cannot load symbol: /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgsthailotools.so: undefined symbol: filter
Segmentation fault.
there is no single page that describes how to install get the items.
Ultralytics system are far better - you dev team should work like that
Hi @sham,
Thanks for reaching out and sharing the error message. The issue you’re seeing is most likely related to an incomplete installation.
However, from your message it is not clear what platform you are using, nor when this error occurs (for example, are you trying to run a specific app?)
To help us diagnose this properly, could you please let us know:
- Which platform and operating system you are running (e.g., Raspberry Pi OS, Ubuntu, Yocto, etc.). I noticed from the error that it is a aarch64 platform.
- Which Hailo device or module you are using (e.g., Hailo‑8, Hailo‑10H)
- How you installed the Hailo software components:
- Generally, you can start from the Hailo Developer Zone andd set up the SW components you need.
- If you have a Raspberry Pi 5 AI HAT, you should follow the official installation instructions from Raspberry Pi, as the entire installation process is easier:
Raspberry Pi - AI HAT+ Documentation
Raspberry Pi - AI HAT+ Software
Your hardware is good . but kindly give one liner installation system
like ultralytics
please make a script something like
pip install hailo8
the ultralytics guys have done a wonderful job in installation
thanks
