Sorbet
April 8, 2025, 8:44am
Hello community,
I’m hailo15H user.
I ran the file downlaod “yolov5m_nv12.hef” file from Hailo Model Zoo.
And run “Hailortcli path-hef yolov5m_nv12.hef” to get information of this file.
But, HEF version does not match error is occured.
[HailoRT] [error] CHECK failed - HEF version does not match. Should be 1 but detected 2
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_INTERNAL_FAILURE(8)
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_INTERNAL_FAILURE(8)
An error like this appears.
What should I do in this case?
Hi! I have the same issue, but coming from a different situation: basically I followed the procedure for compiling a custom .hef file through WSL and Hailo Dataflow Compiler. I managed to obtain the hef file but when I try to open it, I get the exact same error.
The versions I have been using are:
packages installed in WSL Ubuntu 22.04 for conversion onnx → hef:
golang-github-hailocab-go-hostpool-dev/jammy 0.0~git20160125.0.e80d13c-1.1 all
hailort/now 4.20.0 amd64 [installed,local]
hailo-dataflow-compiler 3.31.0
hailo-model-zoo 2.15.0 /home/btsuser/hailo_model_zoo
hailort 4.20.0
packages installed in a RaspberryPi 5, on which I would like to open the hef file (thorugh C++ project):
golang-github-hailocab-go-hostpool-dev/stable,stable 0.0~git20160125.0.e80d13c-1.1 all
hailo-all/stable,stable 4.20.0 all
hailo-dkms/stable,stable,now 4.19.0-1 all [installed]
hailo-tappas-core-3.28.2/stable 3.28.2 arm64
hailo-tappas-core/stable 3.31.0+1-1 arm64 [upgradable from: 3.30.0-1]
hailofw/stable,stable,now 4.20.0-1 all [installed,automatic]
hailort-pcie-driver/now 4.19.0 all [installed,local]
hailort/stable 4.20.0-1 arm64 [upgradable from: 4.19.0-3]
python3-hailort/stable 4.20.0-1 arm64 [upgradable from: 4.19.0-2]
rpicam-apps-hailo-postprocess-dbgsym/stable 1.7.0-1 arm64
rpicam-apps-hailo-postprocess/stable 1.7.0-1 arm64
Any help would be appreciated, thanks
Same issue, same packages, does anyone know why?
omria
May 21, 2025, 10:14am
4
Hey @Simone_Tortorella @Giorgio_Marcuccio ,
Just checking in — is this issue still happening?
From what I see, it looks like you have the driver from 4.19 but are running HailoRT 4.20 . That mismatch could be causing problems.
Also, if you’re using HailoRT 4.20 , make sure you’re compiling with DFC 3.30 for full compatibility.
Let me know where things stand — happy to help troubleshoot further if needed.
Issue resolved, I had to install the latest versions in a certain order. Thanks
